'84 Flat-Four Posted July 13, 2010 Share Posted July 13, 2010 I'm posting for a co-worker who drives the above. She is having trouble getting into 1st gear. She says its easier if she goes into reverse then into 1st. Would this be a clutch cable adjustment? I do not want to advise her based on my Soob experience, but something tells me I may not be too far off base. I couldn't locate an FSM or Haynes on the web that i could peruse. Any help offered is appreciated very much! Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted July 14, 2010 Share Posted July 14, 2010 Unfortunately, I believe those cars have a hydraulic clutch. So, it may be a linkage problem. Have her, or her mechanic, look at the linkage trail and see if there's anything catching. Twitch Link to comment Share on other sites More sharing options...
'84 Flat-Four Posted July 14, 2010 Author Share Posted July 14, 2010 Will do. Thanks Twitch! Twitch de la Brat said: Unfortunately, I believe those cars have a hydraulic clutch.So, it may be a linkage problem. Have her, or her mechanic, look at the linkage trail and see if there's anything catching. Twitch Link to comment Share on other sites More sharing options...
jason2o Posted October 5, 2010 Share Posted October 5, 2010 The trannies on the GTS SUCK, I went through 2 in 45k on my '00 GTS. I got accused of racing etc. , it was my commuter the problem ended up being the synchro's on the 6spd is of sintered metal construction so they would die young. The later models lasted a little longer because the Rev. limit was lower then the '00. Link to comment Share on other sites More sharing options...
