tkaste Posted July 18, 2010 Share Posted July 18, 2010 CEL just came on on me 1995 Lego. Advanced Aiuto read the code and it is a knock sensor malfuction. Its $78 for the part but I have no idea where on the car it is located. thanks for any help Link to comment Share on other sites More sharing options...
Cougar Posted July 18, 2010 Share Posted July 18, 2010 I think it is located on top of the engine, near back of it, possibly more on the passenger side of the engine. Look for a device screwed into the engine block. Sometimes this kind of trouble can be cleared by simply cleaning the connection to the sensor. The code will go away immediately when the trouble is corrected. Link to comment Share on other sites More sharing options...
heartless Posted July 18, 2010 Share Posted July 18, 2010 what engine? if it is 2.2 - unless they made a location change between 1990 & 1995 - it is located on the top of the engine block, just to the drivers side and behind the intake... standing next to the drivers side strut tower - lean over, look straight down just behind the intake - you may need to move wiring harness or throttle cables a little to get a good view of it - one bolt holds it on going right thru the middle. Link to comment Share on other sites More sharing options...
john in KY Posted July 18, 2010 Share Posted July 18, 2010 Just replaced the one on my car and Heartless has the correct location. Really way down there but it is down there. Don't overtorque the mounting bolt. Thinking something like 17lbs. Link to comment Share on other sites More sharing options...
macattack Posted July 18, 2010 Share Posted July 18, 2010 $78 for a new sensor? That doesn't sound right. Check Autozone.com. You can get a new sensor with 2yr warranty for $56. Replacing it is a 10 minute job. Very easy. Link to comment Share on other sites More sharing options...
heartless Posted July 18, 2010 Share Posted July 18, 2010 parts pricing WILL vary by location, that said, looking up the sensor at autozone.com using the correct PA zipcode turns up a price of $44.99 it is quite common to find a cheaper price for a part at a retailers website than you will find in store - check the website first - print out the page of the part you need and take it with you to the store - 98% of the time they will give you the cheaper price. (i do this all the time with advance) Link to comment Share on other sites More sharing options...
tkaste Posted July 18, 2010 Author Share Posted July 18, 2010 thanks for all the advice. Just went to autozone web site - $44.99. about 6 miles out off the way compared to Advance Auto but for $34 I think it will be worth it. I ound on the engine block after looking at the picture on autozone, drivers side tucked under the throttle body I like this board. I just picked this car up a few months ago and no major problems just minor inconviences and every time i post a question I get an answer that is dead on. not bad for 1995 EJ22 with 165,000 on it. Any advice on making it last a while. The last owner did excellent maint. Belts, all fluids... so based one what I have read on Subie's just keep up the routine maint. and it will go forever(hoepfully) Link to comment Share on other sites More sharing options...
Olnick Posted July 18, 2010 Share Posted July 18, 2010 Advice? Keep on with what you're doing--learn all you can about your car, pay attention to any little signs of a problem, always check out CELs. Sounds like the previous owner gave you a good start, that's great. Keep up with the routine/preventive maintenance and your car probably will last "forever!" The '95 EJ22 is an excellent engine, I can vouch for that. But you've already done the best thing you can do for your Subie--you joined USMB! Link to comment Share on other sites More sharing options...
heartless Posted July 19, 2010 Share Posted July 19, 2010 But you've already done the best thing you can do for your Subie--you joined USMB! yup - what olnick said! seriously tho, just pay attention to your Suby and keep her maintained and she will run and run and run - the body will give out before the motor does. Link to comment Share on other sites More sharing options...
tkaste Posted July 20, 2010 Author Share Posted July 20, 2010 Just replaced the Knock Sensor. Unbelievable how much differnce it made. On the way to AutoZone could not even be in 5th gear on any type of incline, she would just bog down an loose speed. Now all is good again:banana: Thanks to all for your help Link to comment Share on other sites More sharing options...
logic23 Posted July 20, 2010 Share Posted July 20, 2010 it also helps to clean the block where the sensor mounts.... fyi Link to comment Share on other sites More sharing options...
heartless Posted July 20, 2010 Share Posted July 20, 2010 Just replaced the Knock Sensor. Unbelievable how much differnce it made. On the way to AutoZone could not even be in 5th gear on any type of incline, she would just bog down an loose speed. Now all is good again:banana: Thanks to all for your help glad to hear you got things straightened out. It is a good feeling, isnt it? Link to comment Share on other sites More sharing options...
Olnick Posted July 20, 2010 Share Posted July 20, 2010 Now all is good again:banana: That's great news! And thanks for letting us know the outcome. Link to comment Share on other sites More sharing options...
