mdjdc Posted July 20, 2010 Share Posted July 20, 2010 I have the opportunity to buy a 98 legacy with 130k on it for cheap. The issue is that it won't shift out of 1st gear. I am prepared to swap in another tranny, but I figured I'd check with you all to see if there is something I should check before jumping to the swap. Thanks Guys Link to comment Share on other sites More sharing options...
johnceggleston Posted July 20, 2010 Share Posted July 20, 2010 mdjdc said: I have the opportunity to buy a 98 legacy with 130k on it for cheap. The issue is that it won't shift out of 1st gear. I am prepared to swap in another tranny, but I figured I'd check with you all to see if there is something I should check before jumping to the swap. Thanks Guys auto or manual? Link to comment Share on other sites More sharing options...
mdjdc Posted July 20, 2010 Author Share Posted July 20, 2010 Sorry. Automatic trans Link to comment Share on other sites More sharing options...
johnceggleston Posted July 20, 2010 Share Posted July 20, 2010 what happens if you unplug the trans wiring harness.? does it default to limp mode 3rd, or stay in first.? can you manually shift it out of first? Link to comment Share on other sites More sharing options...
idosubaru Posted July 20, 2010 Share Posted July 20, 2010 yeah check the linkage and the inhibitor switch on the front passengers side of the trans, could be broken/seized. Link to comment Share on other sites More sharing options...
mdjdc Posted July 20, 2010 Author Share Posted July 20, 2010 I am asking these questions now, but I haven't gotten the car yet. I am looking for an easier fix once I pick it up. Gary when you say the inhibitor switch, do you mean the neutrl safety switch, or is it different? I figure it might be an electrical problem and that is why I posed the question and I appreciate the heads up. If anyone else has some suggestions please hit me with them. Link to comment Share on other sites More sharing options...
