Twitch de la Brat Posted July 21, 2010 Share Posted July 21, 2010 (edited) How to service your clutch and parts located in the bellhousing WITHOUT removing your transmission or draining the fluid 1. Lift the car up approx 1ft and support it properly 2. Place your jack directly under the transmission and apply a small amount of pressure to the bottom of the tranny, using the jack. 3. Unhook all cables and wires from the tranny, this is very important if you don't want to have to replace your speedo cable. 4. Unbolt the 4 bellhousing bolts 5. Secure the driveshaft to the rear of the transmission, baling twine or tie down straps work fine for this. 6. Unbolt the driveshaft from the rear diff, it should fall off the diff easily 7. Make sure the driveshaft doesn't slide out of the rear of the tranny, tighten your attaching strap as necessary to prevent this 8. Unbolt the tranny crossmember, allowing the weight of the tranny to rest on the jack. 9. Separate the transmission from the engine, this part may require some wiggling and finagling, but do not let it drop off the jack or the crossmember. 10. Slide the tranny back far enough to access the parts to be serviced (disclaimer, you may have to remove the clutch/pressure plate/flywheel to access some parts) 11. Service necessary parts 12. Installation is the opposite of removal. Sorry for the lack of pix, last time I did this I didn't have a camera available Twitch Edited July 21, 2010 by Twitch de la Brat Forgot about the tranny crossmember 2 Link to comment Share on other sites More sharing options...
Subruise Posted July 21, 2010 Share Posted July 21, 2010 good call twitch, also I might add I use shorter bolts for the two on the bottom of the bell housing that are really hard to deal with. Ive used them for years now and as long as they are good bolts(ie machine quality) I dont see a problem with them. It makes the whole process faster (thanx dad) Rob Link to comment Share on other sites More sharing options...
