3prongpaul Posted July 23, 2010 Share Posted July 23, 2010 I took apart a 98 Outback engine 2.5 DOHC to do head gaskets timing belt etc...found this part in the garage left over...not sure if it is from the outback or a different car... ...can anyone confirm where this goes if from an Outback? . . Quote Link to comment Share on other sites More sharing options...
logic23 Posted July 23, 2010 Share Posted July 23, 2010 That is not off the outback. Quote Link to comment Share on other sites More sharing options...
Fuzpile Posted July 23, 2010 Share Posted July 23, 2010 (edited) Is that a rubber type backing on that angle? If so it doesn't go near the header which I origionally thought. That vibration damper would suspend a bracket of hydraulic lines or something so they don't go thru a million vibrations. Edited July 23, 2010 by Fuzpile Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted July 24, 2010 Share Posted July 24, 2010 That doesn't really look like it goes on the outback.. and if it does it looks superfluous. (maybe holds a wiring harness "in place" or something.) Looks older though. Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted July 24, 2010 Share Posted July 24, 2010 kinda looks like a belt cover bracket? like the cover bolts to it, then it to the block? -Justin Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 24, 2010 Share Posted July 24, 2010 looks like the mount for the MAP sensor and swithching solenoid.....kinda anything look missing between the air cleaner and the strut tower? the bolt part does look like Subaru threads. Quote Link to comment Share on other sites More sharing options...
davebugs Posted July 24, 2010 Share Posted July 24, 2010 By the alternator to hold the alt belt shroud? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 24, 2010 Share Posted July 24, 2010 By the alternator to hold the alt belt shroud? Bingo Looking again I'm pretty sure that goes on the upper, front AC compressor bolt and holds the far end of the AC belt cover. Quote Link to comment Share on other sites More sharing options...
davebugs Posted July 25, 2010 Share Posted July 25, 2010 Bingo Looking again I'm pretty sure that goes on the upper, front AC compressor bolt and holds the far end of the AC belt cover. Oops - yea that's what I meant. Holds that little piece of black plastic that covers the pulley on the AC unit and is held on by one of the long AC compressor bolts. Because I've forgotten the bracket in the past. Quote Link to comment Share on other sites More sharing options...
wtdash Posted July 25, 2010 Share Posted July 25, 2010 Oops - yea that's what I meant. Holds that little piece of black plastic that covers the pulley on the AC unit and is held on by one of the long AC compressor bolts. Because I've forgotten the bracket in the past. +1 That one's a PITA to put back on as you have to remove an AC bolt. Not hard, just extra work! (Yes, been there/done that!):-\ GL, TD Quote Link to comment Share on other sites More sharing options...
