Legacy 90' 4eat transmission gets stuck on first and lately it's been going on "limp mode" after I've been running it for awhile and its hot, only if turned off and then back on again. If I don't turn it off it works fine and if it cools down it works good too. Got repair done master kit and shift kit hoping that was the problem, but no luck. Mechanic still working on it for a month now. He can't figure out the problem. No Subaru dealer around my area wants to work with it.....I need help!!
Sensors break down. Like spark plugs that test great but won't fire over compression. There is a sensor for AT temp which goes directly into the ecu. Why can't that stick when it gets old? Great one way or another but lagging like a bad thermostat.
i'd invest some time in an FSM - they should be fairly explicit about what to do if you have limp mode and stuck in first gear.
if the transmission light is ever blinking or the check engine light then you need those codes. have you ever seen any lights at all on the dash? if not, make sure they work.
TPS is used in the shifting algorithm, not sure if that would cause your symptoms but the contacts in them do fail and get less responsive with age.
this sounds fairly repeatable, something is sticking or something.
Thank you! Guys for all your help. It's the TCM like you guys said. Planning on replacing it, any advice in where to find it new for the best price??
http://www.car-part.com
i don't know if they can or will ship to where you are but that's the site.
but first post an ad in the parts wanted section of the classifieds here at usmb. some one is bound to have one on the shelf.
http://www.ultimatesubaru.org/forum/forumdisplay.php?f=37
Let's hope that you've discovered the source of your problem. Do you have a source for a new or used one in PR? Any salvage yards or pull-and-pays?
Good luck--hope this gets you up and running again.
Thanks man! I know a place that fixes tran. computers, if fixable and a source for a new one, but no source for a use tcm except for a couple of websites but no luck. I really hope that's the problem too. take it easy
