Noob needs HELP EA82 spfi
Ok i got an EA82 SPFI was told its from a 91, but came to me in a VW. the wiring is a mess. Can someone point me in the direction of a wiring diagram and what signals the ECU look for. Was able to start with starting fluid but fuel pump doesnt come on and injector not firing. didnt know where to post this sorry.
hi there, and welcome to the USMB!
might be able to come up with some wiring diagrams later if i do a little digging - about to head into town right now - or someone else may pipe up and get you pointed in the right direction. you might try doing a search and/or taking a look in the USRM - might be something there.
as for your questions & where to post - either the "older gen" section or in the "subaru modifications" area - not sure which of the two subforums would be appropriate tho...
again, welcome aboard - and be patient - not a lot of the "guru's" check in here. :)
