SwimShady Posted July 26, 2010 Share Posted July 26, 2010 I'm trying to find a replacement driveshaft for my 99 Outback, and was wondering if 97 or 98 would be compatible. Link to comment Share on other sites More sharing options...
logic23 Posted July 26, 2010 Share Posted July 26, 2010 all outback and legacy driveshafts are the same except for the carrier bearing which you can swap from one to the other. The differences in the bearing is the height off the bottom of the car. If i remember right outbacks are taller. There is also a difference in length from the autos vs 5 speeds. The 5speeds are shorter. Link to comment Share on other sites More sharing options...
logic23 Posted July 26, 2010 Share Posted July 26, 2010 Are your u joints bad? They are nissan u-joints and a machine shop should be able to install new ones. Link to comment Share on other sites More sharing options...
SwimShady Posted July 26, 2010 Author Share Posted July 26, 2010 I had a bad one that got thrown yesterday, and at this point it's going to be easier to replace the whole assembly. Thanks for the info! Link to comment Share on other sites More sharing options...
svxpert Posted July 27, 2010 Share Posted July 27, 2010 where are you located? i have a few new ones (less than 1000 miles) in my shop in NJ. Link to comment Share on other sites More sharing options...
crcorc Posted August 14, 2010 Share Posted August 14, 2010 Are your u joints bad? They are nissan u-joints and a machine shop should be able to install new ones. Interested to know which Nissan joints wil fit a '98 outback. Thanks. Link to comment Share on other sites More sharing options...
danw77 Posted August 23, 2010 Share Posted August 23, 2010 where are you located? i have a few new ones (less than 1000 miles) in my shop in NJ. hey, i'm in NJ and looking for a new driveshaft for my 2000 Outback MT. Where are you? Link to comment Share on other sites More sharing options...
svxpert Posted August 24, 2010 Share Posted August 24, 2010 "hey, i'm in NJ and looking for a new driveshaft for my 2000 Outback MT. Where are you?" 08080 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 24, 2010 Share Posted August 24, 2010 all outback and legacy driveshafts are the same except for the carrier bearing which you can swap from one to the other. There is also a difference in the rear diff flange from 90-94 and 95+ driveshafts. The bolt pattern and size is different so you have to swap the flange on the diff end to swap the driveshafts. I think the difference is between innie vs. outie rear axle DOJ's. GD Link to comment Share on other sites More sharing options...
logic23 Posted August 25, 2010 Share Posted August 25, 2010 I'm not sure which Nissan joints fit. When I take the subaru driveshafts to the rebuilder they always say," Oh yeah I remember...these have the Nissan joints". So I'm sure if you call a rebuilder they could tell you. Link to comment Share on other sites More sharing options...
