dzld231 Posted July 26, 2010 Share Posted July 26, 2010 Need to release the E-Brake on my 90 Subaru Loyale.... What is the easiest way? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 26, 2010 Share Posted July 26, 2010 find out which side is stuck. first thing i'd do is just unstick it. remove tire, work it around. i did that once and it never came back. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted July 26, 2010 Share Posted July 26, 2010 If its stuck the cable is probably getting rusted up in the housing. What gary said..pull both front wheels and figure out which cable is seized. You can try working it around but that has never worked for me. If its seized that good then id say just unhook it at the brake for now until you get a new cable. Quote Link to comment Share on other sites More sharing options...
dzld231 Posted July 27, 2010 Author Share Posted July 27, 2010 Got it unstuck by using WD-40 and hit it with my screw driver till I saw it move, then I worked it back and forth by hand till it was released..... But..... The grinding continues..... Gonna have to wait till my next day off and remove the wheels and check my pads..... FAIL. Thought for sure it was just my ebrake. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted July 27, 2010 Share Posted July 27, 2010 Probably the slides on the caliper. Time for a rebuild...or just buy a rebuilt and packed set from Rock auto. They are dirt cheap...like 40 bucks if i remember right. Quote Link to comment Share on other sites More sharing options...
dzld231 Posted July 27, 2010 Author Share Posted July 27, 2010 Or lube the piss out of them............ xD Quote Link to comment Share on other sites More sharing options...
