teasdam Posted February 20, 2004 Share Posted February 20, 2004 the two conditions the manual gives for timing adjustment are... 1) test mode wires connected and 2) idle switch must be ON ...ok, the test wires are simple enough. But now the questions... What do they mean by the idle switch? Is this something I'm supposed to DO, or something the car should do itself and I just need to CHECK? Do I just put a multimeter to the idle switch wire of the TPS and check for power? If so, I don't have a DMM...would a 12V test light suffice? Link to comment Share on other sites More sharing options...
