How do I remove EA82 key tumbler?
Working on a friends car, and the key got stuck when the tumbler locked up :mad:
I know the trick about using a drill to notch the tamper proof bolts and remove the entire lock cylinder, but isn't there a way to remove just the lock portion? My cordless drill sucks, and probably won't notch the ones at the junkyard before the batteries die :-\
Here's a picture of another locked up cylinder I had lying around. There is another identical pin on the other side. I had to use a hammer and punch and really beat on it to get the pins far enough in for it to slide out.
I went to the junkyard today and figured with the key in the right position, those pins would just push in and it would slide right out. I was wrong :mad:
Sooo.... should those pins push in easily to remove the tumbler, or do I need to go medieval on it?
You have to actually pull the pins out. They only go in on the newer generation cars. Makes taking the tumbler ou a real PITA
Weird :mad: My '72 pickup has a little pin that easily pushes in to allow the tumbler to come out. These have to have some trick to remove them.
Guess I'm off to the junkyard with a drill :rolleyes:
