the sucker king Posted July 30, 2010 Share Posted July 30, 2010 What is the biggest obsticle? This is on an 85 that has a 4wd auto tranny. I have done a fwd auto to 4 speed d/r swap on a ea81 era car, all by my lonesome. I know what's involved, just wondering if the ea82 is equally straight forward. My main worry is, Is the tunnel big enough or does it need hammering and/or cutting? the hole for the stick need to be cut bigger, this i understand. I need your imput to decide to buy or not. Link to comment Share on other sites More sharing options...
monstaru Posted July 30, 2010 Share Posted July 30, 2010 i am in the middle of this myself. no tunnel clearance needed. everything fits like it should normally. have not done the shifter yet. i have the engine and trans in the car already.cheers, brian Link to comment Share on other sites More sharing options...
subynut Posted July 30, 2010 Share Posted July 30, 2010 Very straight forward. Just plug and play. Biggest hiccup I ran into when we did that on my brother's 87 was the starter interlock. I shorted two wires on the connector at the AT shifter box on the floor to get the starter to work. Link to comment Share on other sites More sharing options...
monstaru Posted August 1, 2010 Share Posted August 1, 2010 the tunnel seems fine on mine.i thought i had some driveline pieces to fit , but alas i do not.that and the pedal box need done.then finished...cheers, brian Link to comment Share on other sites More sharing options...
hatchsub Posted August 1, 2010 Share Posted August 1, 2010 subynut said: Very straight forward. Just plug and play. Biggest hiccup I ran into when we did that on my brother's 87 was the starter interlock. I shorted two wires on the connector at the AT shifter box on the floor to get the starter to work. Thats with any auto to manual swap...the inhibitor switch that keeps you from starting it in any gear other than park or neutral. You just have to jump two wires (the big ones if i remember right) together. Link to comment Share on other sites More sharing options...
mdjdc Posted August 2, 2010 Share Posted August 2, 2010 I did this not too long ago with my daughter for her build. Very straight forward and the shifter is plug and play also. All of the bolt holes for the shifter boot even line up. She runs great. The only hiccup we had was a problem with the kick down relay circuit. When she would depress the gas pedal too hard the fuse would blow. We ended up finding out which wire went to the computer and cutting it and the problem went away, but now she has a constant CEL. Guess we'll just have to live with that. Good luck Link to comment Share on other sites More sharing options...
