NWSubie Posted July 31, 2010 Share Posted July 31, 2010 I bought a napa oil sending unit and put it on my EA-81 but now the red oil can indicator light on the dash is stuck on all the time. My friend had the same problem with has loyal also. Has anyone else had this problem? Im not sure if Napa is just giving us wrong sending units or if I just got a defective one. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 11, 2010 Share Posted September 11, 2010 I don't know for sure but it seems from the ones I've messed with that on some models the switch is normally open and on some it is normally closed. If you leave the wire unhooked, does the oil light stay on. And when you ground the wire does it go off? Or the other way around? Quote Link to comment Share on other sites More sharing options...
Yo'J Posted September 12, 2010 Share Posted September 12, 2010 I've had no luck with aftermarket senders. Dealer ones are the way to go. I'm wondering how many types they used on the gen two and threes. I'm guessing they might be more year specific than we realize. Quote Link to comment Share on other sites More sharing options...
hackasubaru Posted September 13, 2010 Share Posted September 13, 2010 Was it the oil pressure sending unit or oil pressure switch? If i understood the difference between the two correctly; the sending unit is in charge of the oil pressure gauge and the pressure switch is for the light. Do you have both an oil pressure gauge and light? Quote Link to comment Share on other sites More sharing options...
