harpua Posted July 31, 2010 Share Posted July 31, 2010 I was given this little hatch after it had been stripped and almost ran in a demolition derby. I need help with figuring out how to wire this thing the easiest way possible. Bare minimum, only the essentials to make it run. I think i understand most of what i need to do, but i need make sure i'm not missing something. Everything has been stripped out of it including wiring. I know i have to provide power to the coil, the fan, the fuel pump and the starter solenoid. here are some questions i have. Feel free to add anything you think my be useful in making this work. * Can i just run a hot wire to the + side of the coil and ground the negative side to the block as well as connecting the distributor to the coil? I will be putting a switch on the hot wire from the battery to the coil so i can cut power as needed. * I just need to provide power to the starter solenoid through a momentary switch to make it turn over right? * What do i need to do to get the alternator to work? I haven't even looked at it really to figure it out. I am going to go look at that next. i have the fuel pump and fan figured out. I can't think of anything i missed, but i am sure there is something. I am running low on time, I have to get this running by tomorrow, so any help is appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
themoneypit Posted July 31, 2010 Share Posted July 31, 2010 poor ole hatch.. may it rest in pieces after the figure 8!! Link to comment Share on other sites More sharing options...
