analog.anarchy Posted July 31, 2010 Share Posted July 31, 2010 White smoke from exhaust when I give her gas, not on idle(strange?). was having problems making her hold an idle so I replaced the pcv valve and air filter(the previous was covered in oil from an oil leak) and cleaned out the throttle w/ carb cleaner. She idled on start up and I drove around the parking lot for a little bit, when I tried to accel up to 45 I started billowing white smoke. Please help. Link to comment Share on other sites More sharing options...
maozebong Posted July 31, 2010 Share Posted July 31, 2010 white smoke is 95% of the time is a blown headgasket, if not a intake manifold gasket leak. check for coolant in the oil murky coolant, loss of compression bubbling in the coolant reservoir while running loss of coolant sweet smell by the exhaust other 5% water in fuel lines/tank poor quality fuel cracked block/head Link to comment Share on other sites More sharing options...
analog.anarchy Posted August 1, 2010 Author Share Posted August 1, 2010 Phew! I feel really retarded but I fall into that fortunate 5%. After I had finished working on my car for the idle problem I topped off the oil, in my excitement to be roadworthy again I overfilled the oil by as much as 2 quarts. Sorry to post a false positive. Link to comment Share on other sites More sharing options...
