OBD I- codes 16, 22, 31 after rebuild
Just got my engine installed. I've got a 31, 22, and 16 showing on my engine codes.
Throttle, knock, and injector #3. I'm going to check the wires on number 3 when I'm done posting. Otherwise, the car will only start if you give no throttle, dies when you give any throttle (which tells me it is lean), and then either way it only runs for a couple seconds at higher rpm (1500) and then dies. You can kinda blip the throttle and keep it alive, but not for long.
Any thoughts?
The throttle position sensor code is the one to concentrate on, since the other two won't stop the engine from running. If the TPS was okay before the rebuild, and you didn't "play" with it, then the trouble is likely to be connector related.
I'd suggest carefully rechecking engine connector seating. Make sure they're fully engaged, and that no contacts have gotten bent.
  • 2 weeks later...
I'll admit that I hav oly done a jiggle test... I jiggled all hoses and they felt fine. If I could get it idling I woud try spraying around the hose... Maybe I can build pressurizing adapter like use on my turbo cars to check for leaks...
OK, just remembered a big piece of info. When I put it back together, I had the fuel lines swapped. The fuel was pumping into the return line.
Could that have messed something up? The FPR? I don't know how that'd give a TPS code, but it is something to mention...
