jensen0510 Posted August 6, 2010 Share Posted August 6, 2010 Only a couple of issues.....Gas gauge is goofy. I hear that is standard. Lockout button on Tranny has to be pushed to move from park to Drive or Reverse. Headlight short..... But here's the one I'm worried about......When I put the car in reverse and backup it jerks and shakes....almost like something is getting bound up. Any idea what I should check? Link to comment Share on other sites More sharing options...
johnceggleston Posted August 6, 2010 Share Posted August 6, 2010 ....When I put the car in reverse and backup it jerks and shakes....almost like something is getting bound up. Any idea what I should check? double check to see if it does it all the time backing up or only when turning and backing. see if it does it when turning tight, all the way to the right or left, slow circles, at idle speed while going forward. what i'm looking for is torque bind. if not that then maybe a bad trans mount. Link to comment Share on other sites More sharing options...
jensen0510 Posted August 7, 2010 Author Share Posted August 7, 2010 It doesn't do it going forward at all.....smooth as silk. I have a fairly long driveway and it will do it when I push the gas backing up down the driveway, if I idle down the drive it doesn't seem to do it. My driveway also goes down a slight incline to the street. Now that I think about it, it does it primarily when pushing the gas and backing up. If I idle in reverse and back up it doesn't seem to do it. Thanks Link to comment Share on other sites More sharing options...
jensen0510 Posted August 8, 2010 Author Share Posted August 8, 2010 bump Link to comment Share on other sites More sharing options...
johnceggleston Posted August 8, 2010 Share Posted August 8, 2010 does it do it continuously or or just when you start moving? maybe the rear trans mount or drive shaft universal ?? Link to comment Share on other sites More sharing options...
jensen0510 Posted August 8, 2010 Author Share Posted August 8, 2010 pretty continuously when applying power in reverse. Link to comment Share on other sites More sharing options...
Suzam Posted August 8, 2010 Share Posted August 8, 2010 +1 ON Trans mount, U-joint, CV joint or even a loose or broken dog bone could cause this. Get the car inspected by a mechanic who can put it on a lift to check it out by applying the brakes while in reverse. Shouldn't be too hard to diagnose. Link to comment Share on other sites More sharing options...
Gloyale Posted August 8, 2010 Share Posted August 8, 2010 rear trans mount. Link to comment Share on other sites More sharing options...
jensen0510 Posted August 8, 2010 Author Share Posted August 8, 2010 thanks for the ideas, I'll put it up on jack stands and see what I can see. Link to comment Share on other sites More sharing options...
