TheLoyale Posted August 11, 2010 Share Posted August 11, 2010 I'm gonna rebuild one of my axles on the Legacy (25t axle) I need to find an online retailer that sells the correct bearings for the DOJ and the oblong bearings for the CVJ. Anyone have links to axle rebuild store sites? I think this has been touched or brought up once or twice but can't find anything on it. -Tom Quote Link to comment Share on other sites More sharing options...
bstone Posted August 11, 2010 Share Posted August 11, 2010 I just paid United Drive Axle in Chicago $40 to rebuild three axles. However, they do not ship nor do they have a website. If you send me your axle I'll have them do it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 12, 2010 Share Posted August 12, 2010 I'm gonna rebuild one of my axles on the Legacy (25t axle) I need to find an online retailer that sells the correct bearings for the DOJ and the oblong bearings for the CVJ. Anyone have links to axle rebuild store sites? -Tom In order to "rebuild" an axle correctly you are basically only saving the shaft. The rest of the components are wear items - cups, races, balls, boots, etc, etc - all that stuff are wear items. I would start by calling Rockford CV. http://www.rockfordcv.com/ They have been around and been talked about here for ages. I've never called them but it would be interesting to see what a full joint/boot set would run. Personally I just buy new EMPI axles for $69 each and be done with them. Other than a few boot failures I've not had a problem with any of them yet. GD Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted August 12, 2010 Author Share Posted August 12, 2010 So then really, whats the point on saving the shaft? Why not just buy a new shaft aswell - then you might aswell just buy a complete axle Lol. Well then maybe I won't rebuild the two extra axles I have, I will just disassemble and clean and re-boot. As for EMPI, where would you find them? I will do a little research on the net, do you order them right from them online or what? Cheers and thanks guys! -Tom In order to "rebuild" an axle correctly you are basically only saving the shaft. The rest of the components are wear items - cups, races, balls, boots, etc, etc - all that stuff are wear items. I would start by calling Rockford CV. http://www.rockfordcv.com/ They have been around and been talked about here for ages. I've never called them but it would be interesting to see what a full joint/boot set would run. Personally I just buy new EMPI axles for $69 each and be done with them. Other than a few boot failures I've not had a problem with any of them yet. GD Quote Link to comment Share on other sites More sharing options...
