johnceggleston Posted August 13, 2010 Share Posted August 13, 2010 i picked up a 98 outback with bad HGs that has been sitting for ~18months and the brand new rotors (and pads) he put on the week before are now rusty. i pulled them to take and get them turned for my daily driver, but i was wondering if there was a process i could do myself to save the trip. my daily driver needs rotors and i thought i would use these while the 98 is on jack stands and have mine turned to install once the swap is done. i just don't know how much hand sanding , if any, is too much. any tricks or tips?? thanks, Link to comment Share on other sites More sharing options...
davebugs Posted August 13, 2010 Share Posted August 13, 2010 I've usually found that where the pads sat is hard to do by hand well enough. If the rust got deep enough they will never really get totally smooth and you'll notice it a little when driving. If I have a car set for a year I plan on new rotors/pads and I closely check the brake lines (living in the rust belt and car is often parked in grass). Link to comment Share on other sites More sharing options...
Rooster2 Posted August 13, 2010 Share Posted August 13, 2010 If not rusted to oblivion, I would install the rusty rotors, and drive ez for a while, and let the brake pads sand down the rotors. If rusted badly, it is best to remove the rotors and get them turned. There are two bolts that hold the rotor in place. They can be difficult to remove. Suggest you use some PB Blaster, and wait a half hour or so for the Blaster to loosen the rust. I just replaced my front rotors this past weekend, so the rusted in place bolts are fresh in my memory. Link to comment Share on other sites More sharing options...
subaru360 Posted August 13, 2010 Share Posted August 13, 2010 I've had limited sucess knocking the rust of with a belt sander. The right way is to just replace them. Most places won't cut rusty rotors because the rust chews up the tips on the lathe. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 13, 2010 Share Posted August 13, 2010 You can clean them up with a wire wheel on a bench grinder. But if there is any pitting you'll need to have them turned or replace them. Link to comment Share on other sites More sharing options...
johnceggleston Posted August 13, 2010 Author Share Posted August 13, 2010 well i took them by the machine shop today and learned that they are not new, they were turned just before it was parked. and there is not enough left to turn them. so it is either use them as is or toss them. i think i will try them as a temporary while i get my daily driver rotors turned. if they end up working well, ok but if not i'll just get new. by the way, while talking to the machine shop i learned, rotors turned = 12$ each heads cleaned and "vacuume checked" = 20$ each heads resurfaced = 47$ each comments ?? this is my first ever conversation with a machine shop. Link to comment Share on other sites More sharing options...
Durania Posted August 14, 2010 Share Posted August 14, 2010 I have had amazing luck with the wearever rotors on my 95 outback. Like 75 bucks at the Advance Auto. Link to comment Share on other sites More sharing options...
lmdew Posted August 14, 2010 Share Posted August 14, 2010 Use a stiff wire wheel on a 4" grinder, it will clean off all the rust without damaging the rotors. Very good prices on the other machine work. Link to comment Share on other sites More sharing options...
