power window trouble
Hey, my power windows in my xt6 decided to stop working today, and I was wondering if anyone else has had this problem before. the electric motors do not make any attempt to move either window, which makes me think that they are not getting any power. I replaced the fuse labeled "Meter Engine (Window)", and still nothing. Any ideas?
I have had good luck taking the switches apart and cleaning the contacts. Be extremely careful as there are a lot of small parts inside.
Remove the door panel and unplug the switch then remove it from the panel. Take the screws out of the back and carefully pull apart. I would do this over something that can catch any small parts that may fall out. Inside will be small rocker contacts clean both ends and the contact surface in the switch. Reassemble in reverse order and plug in the switch try before you put it back in the panel.
Good luck and pay attention to how it comes apart.
