wrongturninwv Posted August 18, 2010 Share Posted August 18, 2010 What kind of socket do you use on the valve cover bolts on the 95 2.2 engine. thanks Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted August 18, 2010 Share Posted August 18, 2010 What kind of socket do you use on the valve cover bolts on the 95 2.2 engine. thanks i think it's a 10, if not then a 12, just like almost every other bolt. until you start removing large components, then you need a 14 . Quote Link to comment Share on other sites More sharing options...
vasy Posted August 18, 2010 Share Posted August 18, 2010 On my 96 OBW 2.5, it's 10mm. I think the torque setting specified by FSM is about 4 ft.lb, but not sure. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 18, 2010 Share Posted August 18, 2010 10mm Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted August 19, 2010 Share Posted August 19, 2010 10mm is the size. On some models one of the bolts is really close to a cross member and a flex socket or flexible ratcheting wrench can be helpful on that one. Quote Link to comment Share on other sites More sharing options...
