Speedbuggy Posted August 19, 2010 Share Posted August 19, 2010 (edited) Hi, can someone find a typical coolant flow diagram for me (or at least break it down for me in text)? Something that shows the typical direction of flow, and in what order everything is in? The coolant system is a bit different on my buggy so I'm trying to figure out what the factory set up was as a point of reference. I'm coming from the air-cooled VW world, so I'm unfamiliar with this stuff! Edited August 19, 2010 by Speedbuggy Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 19, 2010 Share Posted August 19, 2010 Speedbuggy said: Hi, can someone find a typical coolant flow diagram for me? Something that shows the typical direction of flow, and in what order everything is in? The coolant system is a bit different on my buggy so I'm trying to figure out what the factory set up was as a point of reference. I'm coming from the air-cooled VW world, so I'm unfamiliar with this stuff! flow in the block? Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 1-3-2-4 said: flow in the block? Not really..other than confirming that's where the water pump is.. but where does it go after leaving the engine and does it leave from the top or bottom? How does the route differ between a closed or open thermostat? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 19, 2010 Share Posted August 19, 2010 Speedbuggy said: Not really..other than confirming that's where the water pump is.. but where does it go after leaving the engine and does it leave from the top or bottom? How does the route differ between a closed or open thermostat? fluid comes into the radiator from the top and leaves from the lower hose I'm about 95% sure on that.. now as far as the closed T-stat not too sure about that. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 19, 2010 Share Posted August 19, 2010 From other threads http://www.ultimatesubaru.org/forum/showthread.php?t=67780 Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 Thanks for the link... Seems to be a lot of confusion in this area! Unfortunately the links in that thread are all dead. But so far I've learned that the coolant flows bottom to top of engine and top to bottom of radiator. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 19, 2010 Share Posted August 19, 2010 Speedbuggy said: But so far I've learned that the coolant flows bottom to top of engine and top to bottom of radiator. That is correct.. and I hope someone can chime in about how the flow is with the T-stat open and closed. Link to comment Share on other sites More sharing options...
T'subaru Posted August 19, 2010 Share Posted August 19, 2010 what engine ya dealing with? Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 Quote what engine ya dealing with? ej25d. Link to comment Share on other sites More sharing options...
johnceggleston Posted August 19, 2010 Share Posted August 19, 2010 1-3-2-4 said: That is correct.. and I hope someone can chime in about how the flow is with the T-stat open and closed. i guess i could be wrong about this, but the water doesn't flow with the t-stat closed. (except maybe to the heater core, not sure about that.) the whole point of it being closed is to prevent flow so it will warm up. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 19, 2010 Share Posted August 19, 2010 johnceggleston said: i guess i could be wrong about this, but the water doesn't flow with the t-stat closed. (except maybe to the heater core, not sure about that.) the whole point of it being closed is to prevent flow so it will warm up. if I can remember (tired) I think the water pump has a bypass so it will flow around until it warms up Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 johnceggleston said: i guess i could be wrong about this, but the water doesn't flow with the t-stat closed. (except maybe to the heater core, not sure about that.) the whole point of it being closed is to prevent flow so it will warm up. Wouldn't that damage the waterpump? Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 OK, I found this online, but it's still not exaclty clear what happens when the thermostat changes state. If someone could shed some light on that that would be great. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 19, 2010 Share Posted August 19, 2010 Mostly what changes is flow through the radiator. The other parts of the system will still have flow regardless of thermostat position. I would assume that it would be greater than normal flow rate during the warm up period due to the vacuum created by the water pump. It normally pulls large amounts of coolant from the radiator, which can't be done if the thermostat is closed. This builds vacuum in the system on the "pull" side of the impeller, which will accelerate coolant flow from any other hoses or passages leading to the water pump. There will be a small amount of coolant moving in the radiator, but not a significant amount until the thermostat heats up and opens. Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2010 Share Posted August 19, 2010 Found this flow diagram in porcupine73's wonderful collection (thanks, porc!) It's for a '96 EJ22 but I think the flow would be the same. Don't know how to paste it in here but here's a link: http://www.porcupine73.com/pics/coolant/coolant-flow-diagram.gif Link to comment Share on other sites More sharing options...
johnceggleston Posted August 19, 2010 Share Posted August 19, 2010 (edited) to display like below, place the "http pic location" which you posted above in place of 'pic location' the middle of this: Edited August 19, 2010 by johnceggleston Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 (edited) Olnick said: Found this flow diagram in porcupine73's wonderful collection (thanks, porc!) It's for a '96 EJ22 but I think the flow would be the same. Don't know how to paste it in here but here's a link: http://www.porcupine73.com/pics/coolant/coolant-flow-diagram.gif Finally, that one is much clearer. Thanks for your help everyone. Also, where can I find the rest of this collection you refer too? Edited August 19, 2010 by Speedbuggy Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2010 Share Posted August 19, 2010 johnceggleston said: to display like below, place the "http pic location" which you posted above in place of 'pic location' the middle of this: Thanks, johnc! But where did you get the "xxxxx from? Or do you type it out like I just did?!! Link to comment Share on other sites More sharing options...
johnceggleston Posted August 19, 2010 Share Posted August 19, 2010 (edited) Olnick said: Thanks, johnc! But where did you get the "xxxxx from? Or do you type it out like I just did?!! you type it out , but you need to make sure it is typed correctly. there is a forward / in the second set of brackets. this format is very similar to the "click here" links you can insert in a text. there is a link in my signature. apparently this is standard formatting for "internet" stuff. or if you open a photobucket account and up load some pics there you can click on the 'IMG code' below an uploaded pic and it will format your pic for you. then you just paste it in the post. you can test it by sending yourself an email with a pic inserted. Edited August 19, 2010 by johnceggleston Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2010 Share Posted August 19, 2010 Thanks johnc. Forgive me everyone but I just gotta' try a test!!! Edit: Hmmmm! Well, I guess I did something wrong. Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2010 Share Posted August 19, 2010 Speedbuggy said: Also, where can I find the rest of this collection you refer too? I'd suggest you PM porcupine73 as a courtesy and ask his permission. He's a very helpful fellow and I'm sure he would share. Glad the graphic helped you. Link to comment Share on other sites More sharing options...
johnceggleston Posted August 19, 2010 Share Posted August 19, 2010 Olnick said: Thanks johnc. Forgive me everyone but I just gotta' try a test!!! Edit: Hmmmm! Well, I guess I did something wrong. pm sent. Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2010 Share Posted August 19, 2010 (edited) johnceggleston said: pm sent. Thanks john. Try again: ??? Edited August 19, 2010 by Olnick Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2010 Share Posted August 19, 2010 Olnick said: Thanks john. Try again: Edit: ((Well, that didn't work either. Back to the drawing board!)) Link to comment Share on other sites More sharing options...
Speedbuggy Posted August 19, 2010 Author Share Posted August 19, 2010 Olnick said: Olnick said: Thanks john. Try again: Edit: ((Well, that didn't work either. Back to the drawing board!)) Olnick, when you're pasting the address to the image where are you copying it from? Link to comment Share on other sites More sharing options...
