87glsubie Posted August 20, 2010 Share Posted August 20, 2010 so driving straight down the road there is a wierd roaring sound (like an intense version of knobby tire noise) coming from the front of my 87 wagon. but if i go around a right hand turn it goes away and sounds smooth and quiet like it should be. im very certain its a ball joint. just not sure which one. any ideas??? Quote Link to comment Share on other sites More sharing options...
Indrid cold Posted August 20, 2010 Share Posted August 20, 2010 possible front axle bearing going/gone bad..... loose axle nut... possibly pull cotter pin and see if you can snug main nut... not sure how a ball joint makes a noise...hmmmm...... drive it down the road for 15 minutes with few stops, get out and feel around for hot spot, yes rotor will be hot but compair left right side, possibly disc is dragging, inner or outer bearing going bad etc.. feel your way around till you find something that is way hot.. possibly the issue.. my .02 cents.. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 20, 2010 Share Posted August 20, 2010 Sounds like a classic wheel bearing to me. Get yourself some 6207-ZZ-C3's and the seals and knock in a new pair. Ball joints do not cause roaring noises - they can knock, and they will sometimes cause steering slop or the car to steer with the gas pedal. Doesn't sound like your problem at all. GD Quote Link to comment Share on other sites More sharing options...
87glsubie Posted August 21, 2010 Author Share Posted August 21, 2010 sorry i was thinking like a sloppy ball joint causing the camber to vary because the noise goes away when the weight shifts off one side. which also makes sense with the wheel bearing or maybe a tie rod end ball joint being loose messing with the toe in and out. but hey thats probably just the side of me that hopes it isnt a wheel bearing Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 21, 2010 Share Posted August 21, 2010 Wheel bearings are easy - bring it to me in West Linn and I'll change them out for cheap. $75 plus parts. GD Quote Link to comment Share on other sites More sharing options...
87glsubie Posted August 21, 2010 Author Share Posted August 21, 2010 thanks for the offer but im a diy kinda guy besides ive changed them b4 they really arent that hard, and you guys were right after i changed that ball joint it still grrs at me. kudos and thanks for the input Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 21, 2010 Share Posted August 21, 2010 Cool - just make sure you install them correctly. Bearings and how they are treated are their own field of study. If it's done right these 6k series ball bearings should last 200k or more - often the life of the car. But too often people don't really know what they are doing and damage them or install them incorrectly. GD Quote Link to comment Share on other sites More sharing options...
Bash Posted August 21, 2010 Share Posted August 21, 2010 This may not be your case. In my case I did everything to stop the noise from the front end of my 86 gl 4wd. Now the thing should last forever. I replaced all wheel barings, trans diff bearings, ball joints, tierod ends, new rotors and pads as well as shoes on the rear. And a new axle. The problem was the new axel I bought from advance auto. It was crap!!! I bought a new axle from Napa. no noise at all. I am one happy dude. Now I need to get my money back from Advance. Quote Link to comment Share on other sites More sharing options...
