Florin1 Posted August 20, 2010 Share Posted August 20, 2010 Hi guys . I REALLY need some input on what can be the problem on my so spark issue. Car is a 91 Subaru Legacy SS. It has an EJ20G swap on stock harness and the stock 22t ecu. (not to confuse but the car has had the swap for a while and ran). This whole issue started by me shorting something out. What i was doing was moving my ignitor from under the tmic, and accidently touched the positive terminal on the starter motor. Saw a big spark. So i KNEW i blew a fuse. Went to start the car, and sure enough it doesnt. It cranks and cranks but no spark @ the coil pack. (yes the car is still wasted spark, not coil on plug) So far this is what i've troubleshot: I've swapped out off my other turbo leg the coil pack, the knock sensor, the cam sensor, the ecu. I've checked all my fuses in the main box under the hood, and in the kick panel inside. They are all good. I'm gonna pull all the fuses off my other car and replace them just for good measure. I'm also gonna probably swap the crank sensor too. So can/will anyone help?! I'm stumped, and would like to make it out to WCSS today or tomorrow. Thanks in advance. ~Florin Link to comment Share on other sites More sharing options...
Subalicious Posted August 20, 2010 Share Posted August 20, 2010 It seems you have check all the right places. You have me curious. Ill ask around. Seems to me it would be a simple fuse problem. Link to comment Share on other sites More sharing options...
Florin1 Posted August 20, 2010 Author Share Posted August 20, 2010 yeah, unless there is a fuse somewhere else besides the two said locations... Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 20, 2010 Share Posted August 20, 2010 What did you touch it with? The ignitor? If so that very well may have killed it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 21, 2010 Share Posted August 21, 2010 Yes - try another ignitor. They can and do fail resulting in no spark. GD Link to comment Share on other sites More sharing options...
Florin1 Posted August 22, 2010 Author Share Posted August 22, 2010 thanks guys, yeah i fixed it. The new ignitor didnt help. I believe it was one of the sbf-2 fuses, even though it checked out on my multimeter. Anyway, i DO appreciate you guys chiming in, and being so helpful. I will now be a regular on here as well. Link to comment Share on other sites More sharing options...
