Forester vs Impreza radiator?
It would appear that I have a small leak in my Mom's 99 Forester's radiator. Seems to leak at the top corner of the tank when hot and pressurized.
I have a new Impreza radiator. (97) It apprears to be the same thing except that the top tank seems to be a bit smaller.
Can I still use this? Is it just a smaller volume radiator?
Thanks for your time.
Todd
is it near the cap?
i had the same thing on my 97 obw, the leak was at the corner near the cap. i removed the overflow tank tracked it down. replaced the cap and all is good.
i had noticed a loss of fluid, but never saw where until i left it idling in my driveway when i got home one day. after a few minutes i saw the drip.
hope this helps.
I am not 100% sure, but I would say "no". The 1997 Impreza had the 1.8L or 2.2L engine. The 1999 Forester has the 2.5L SOHC engine. The Impreza radiator probably couldn't handle the extra heat.
BTW, when the Forester first came out in 1998 Subaru tried to make do with the clutch from the 2.2L engine. The result was tons of unhappy Forester owners with burnout clutches. Subaru doesn't engineer their parts for extra capacity.
