mikewilke77 Posted August 21, 2010 Share Posted August 21, 2010 Need to know what year 4 runners have similar rear struts to my loyale. I know i have to drill them out a bit, but other advice is welcome. I am going to yoto parts cause I just bent the hell out a brand new stock strut. huh weak link? What do you guys think? Link to comment Share on other sites More sharing options...
Markus56 Posted August 22, 2010 Share Posted August 22, 2010 (edited) I think there is something wrong with the strut you had. all of the gen 3 lifted and non lifted Subarus that i am aware of are running stock struts. and we beat them HARD. do you have any lift? what tires are you running? how do you drive off road? find a used set at your local pullapart/pickandpull/ etc. should run you about 40 bucks. Edited August 22, 2010 by Markus56 Link to comment Share on other sites More sharing options...
mikewilke77 Posted August 22, 2010 Author Share Posted August 22, 2010 I bent the stock, brand new shock/strut, on a camping trip. I've got the 2" lift blocks at 15 degrees. I was loaded down pretty good and running pretty fast down a jeep trail. That said, I have heard the rear shocks are the aquiles heel of a gl/loyale wagon. Someone had posted the part nuber for a 4runner shock that is the same height as the loyale's rear shock. Link to comment Share on other sites More sharing options...
Markus56 Posted August 23, 2010 Share Posted August 23, 2010 A 4runner has a rear coil spring with a shock, not a strut. That would be used on gen 2 subarus that have torsion bars. There is no use for one on a loyale. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 24, 2010 Share Posted August 24, 2010 I've bent front strut tubes on my lifted wagon. If you haven't done that yet then you aren't even close to being rough on your car. I don't think there's a part I *haven't* replaced except the body, fuel tank, and welded rear diff (lucky I guess). Engines, transmissions, axles, control arms, struts, wheel bearings, diff hanger, trailing arms.... the list goes on. The stock dampening from the struts just isn't enough. The solotion is to add an extra shock at each wheel with custom brackets. That's the only way you are going to get your rig to catch serious air and not break the struts. GD Link to comment Share on other sites More sharing options...
Numbchux Posted August 24, 2010 Share Posted August 24, 2010 Markus56 said: A 4runner has a rear coil spring with a shock, not a strut. That would be used on gen 2 subarus that have torsion bars. There is no use for one on a loyale. ummmm....no. gen 3 4runners have a coilover front shock that's almost identical to gen3 subaru rears. here's a Rancho one for a 97 4Runner from RockAuto: I am curious, however. When you say "new stock strut", what brand? Link to comment Share on other sites More sharing options...
Markus56 Posted August 24, 2010 Share Posted August 24, 2010 I see. i wasnt thinking of putting a front toyota part on the back of a subaru Link to comment Share on other sites More sharing options...
mikewilke77 Posted August 25, 2010 Author Share Posted August 25, 2010 thanks for the info guys. BTW it was a monroe sensi trac that gave out after bout 300 miles. Link to comment Share on other sites More sharing options...
Numbchux Posted August 25, 2010 Share Posted August 25, 2010 hmm...I had a pair of Monroes on the back of my loyale for awhile. of course, it was a street-queen....so I wasn't exactly pushing them. EDIT: w00t. 5,000th post! Link to comment Share on other sites More sharing options...
