Mantis_Toboggan Posted August 23, 2010 Share Posted August 23, 2010 I pulled the harness connector at the front turn signal and both wires ground. I also pulled the turn signal connector and got ground through the green/blue and green/red wires. When I pulled the turn signal switch off and took it apart, I saw a relay inside it. Is this the only turn signal relay in the circuit? Also, there is a black/red connector that is independent of the main connector, where does this go? Link to comment Share on other sites More sharing options...
katienadine Posted January 11, 2012 Share Posted January 11, 2012 I've been looking for this relays location. Is it in the steering column? Link to comment Share on other sites More sharing options...
fixingrusinc83 Posted January 22, 2012 Share Posted January 22, 2012 part of combo switch Link to comment Share on other sites More sharing options...
