babyfacefitz Posted August 24, 2010 Share Posted August 24, 2010 My AC went out but was working the day before. I have had trouble with my AC on earlier legacys. With a mutlimeter can I test the see if the AC clutch is out? Michael Quote Link to comment Share on other sites More sharing options...
nipper Posted August 24, 2010 Share Posted August 24, 2010 Year miles? The clutch doesnt go bad that often. First step in ANY ac diagnoses is to get a gauge set on the AC system, if the pressure is too low or too high the compressor will not come on.You most likely have a leak. Pressure slowly went down till the pressure dropped too much si the compressor wont come on, or.... stuff breaks. Quote Link to comment Share on other sites More sharing options...
lmdew Posted August 24, 2010 Share Posted August 24, 2010 Gauges are best, but if you don't have them and want to do a quick check of the clutch, disconnect the pressure switch connector and jump the pins in the plug. You can do the same thing at the AC relays. Don't let it operate this way for more than a few seconds. You'll still need gauges to go further, but at least you know where the problem is. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted August 25, 2010 Share Posted August 25, 2010 Year miles? The clutch doesnt go bad that often. First step in ANY ac diagnoses is to get a gauge set on the AC system, if the pressure is too low or too high the compressor will not come on.You most likely have a leak. Pressure slowly went down till the pressure dropped too much si the compressor wont come on, or.... stuff breaks. My guess too.......low refrigerant level. You prolly need a recharge, and find source of leak. I bet your A/C has not been putting out really cold air for the past week or so? Quote Link to comment Share on other sites More sharing options...
babyfacefitz Posted August 25, 2010 Author Share Posted August 25, 2010 I have an OBW 98 with 224K. The AC had cold air but about the same it has had all along. I loved the cold AC the 90-94 legacy had. I will be checking with gauges later this week but my dealership friend didn't know how the isolate the clutch. Thanks guys. Quote Link to comment Share on other sites More sharing options...
