It possible that the wires could have been damaged...
To pull the codes there is a black pug under the dash to the right of the steering column with two black wires in the same harness . you insert one of the wires (doesn't matter which one) into one of the plugs ( do a search on the forum and you should be able to tell which one) then turn on the ignition. Voila the abs light will start flashing the codes. Nipper has a list of the codes.
