tailgatewagon Posted February 23, 2004 Share Posted February 23, 2004 For those of you who have done the t case mod. i have a couple of questions(or those of you who know) from what ive gathered a nissan 720 transfercase is the ideal. so here is my qusetion how do you mate the two togeter. is it a bolt togher type thing or is it a short drive shaft thing. please if anyone has pix of the process id love to see them. thanks brian Link to comment Share on other sites More sharing options...
soobme Posted February 23, 2004 Share Posted February 23, 2004 The intermedeat shaft from the Datsun/Nissian truck will slip right into the back of the Subaru tans (small world huh) and that is what conects them. It also gives U the proper spacing between the 2. With some slight mods the shifter will then come up right next to the pass. seat in the car;) Link to comment Share on other sites More sharing options...
tailgatewagon Posted February 23, 2004 Author Share Posted February 23, 2004 sweet so all that needs to be done is to fabricate a mount for the t-case and do just slip them together, as fare as putting the two together. thanks . all imput is greatly apreciated. brian Link to comment Share on other sites More sharing options...
Rooinater Posted February 23, 2004 Share Posted February 23, 2004 that's not all... you fab a subframe which you mount it off of. Link to comment Share on other sites More sharing options...
tailgatewagon Posted February 24, 2004 Author Share Posted February 24, 2004 thanks Rooinater thats what i was thinking. should be to hard and. now all i need are legacy diffs and im ready to start. i will probably start with the 3.9s i have and get the bugs out then just upgrade to the 4.11, btw which subys had the 4.44s anyway thanks a bunch. ill post pics when i get somthing acomplished. brian Link to comment Share on other sites More sharing options...
