Found very complete DOHC timing belt set on Ebay, any good?
i like these guys, theimportexperts:
http://motors.shop.ebay.com/theimportexperts/m.html?_nkw=&_armrs=1&_from=&_ipg=
ej22 belt, all idlers and pump, about $125, IIRC.
lots of folks have had good experiences with them.
they also have a retail store somewhere, if you do not see the "package" you want call them, they will put together what you need.
by the way, you probably do not need the tensioner unless yours is leaking fluid. they do not fail very often.
I just started my own company called RetroRoo and I think I can match that price, working on beating it but its tight as they give free shipping too. I don't use any aftermarket cam or crank seals which cuts into it. Factory timing belt and accessory belts, Paraut OEM type water pump, genuine thermostat and gasket. I can add idlers at a very reasonable cost as well.
If somebody wants a custom kit (IE they don't want the tensioner or cam seals or something I can give a quote on that).
Shawn
http://www.retroroo.com
