stephen115 Posted August 30, 2010 Share Posted August 30, 2010 i recently received a 1984 subaru brat from my grandpa(will post pictures later when im done) runs great new engine and trans, i was wondering on how i can lower the rear to level it out so it looks more like a car and rides like one too. Quote Link to comment Share on other sites More sharing options...
84gl Posted August 30, 2010 Share Posted August 30, 2010 Brats Are and Low Geared off road beast most of the time they ride rough and theres not much you can do about it. But you can make it handle better with RX springs on new struts and rebuilting the front end putting pug wheels on it increases the track 1 in which helps a lot But its still a 4wd truck they don't ride like a newer car does and never will But adding the RX springs to the front struts will make it set level by raising the front end up alittle Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 30, 2010 Share Posted August 30, 2010 There is a torsion bar adjustment under the bed that you can use to lower the rear end back to where it's basically level. It's likely been ratcheted up using that adjustment. As for handling..... the options are limited unless you want to do quite a bit of custom work. GD Quote Link to comment Share on other sites More sharing options...
