superpoo93 Posted August 31, 2010 Share Posted August 31, 2010 I was hearing clunking sounds, and could not locate. Only happened when in reverse, then noticed I had a vibration at high speeds. But now its louder,like clunking. Mostly when I slow down, checked the CV Joint on right side and it has play, would it make the clunking sound or do I have to worry that the tranny might be screwed up too?:-\ Link to comment Share on other sites More sharing options...
EA82Version3.0 Posted August 31, 2010 Share Posted August 31, 2010 Definitely the CV. I have the same problem. Vibration at high speeds and clunking when slow / turning. Shouldn't be a problem with the trans if you repair soon. Link to comment Share on other sites More sharing options...
