Sea Foam Insertion, EA82
__aw
I want to Sea Foam my Loyale. Any tips on the best location for adding it? Can I add it where the PCV valve goes in? That location is most convenient. Will it reach all of the cylinders if I add it there? Is there a better place? Thanks.
might i suggest condensing all your questions into one post.
makes it easier for you to track and to answer all in one.
ive always taken the brake booster line off with the car running put my thumb over it so the car doesnt die and adding it little by little till it does die, let it sit then let the smoke show begin!
on a carbureted engine could you just dump it in the carb?
Or you could avoid hydrolocking the engine.
go for the smallest vacuum line, and have it suck it in through that one, you may need to use a spare hose you have laying around the house, but if you suck too much in too fast you'll grenade the engine.
once the can is empty let the car sit for 20 minutes, then start it up and drive hard.
Do this whole thing on a hot engine, a cold one won't clean up as nice.
