1982gl4 Posted September 4, 2010 Share Posted September 4, 2010 I have a 1982 Subaru Gl station wagon with the ea81 still in it. I came across a 4x4 five speed out of an ea82 with the high and low range. So far I have noticed that the transmissions are a different length, and if I remember correctly the clutch is different as well. So what is really involved in this swap. (be honest it wont scare me) I have done a five speed swap in an svx so theres not a hole lot that I feel I can't do, and if I have to make a driveshaft so be it! I do a lot of interstate driving now and feel like my Gl is going to explode turning 4000 rmp in 4th gear :-\ (my car is already a standard) Link to comment Share on other sites More sharing options...
edrach Posted September 4, 2010 Share Posted September 4, 2010 The swap in our Brat involved modifying the transmission cross-member, modifying the shifter linkage, and using the driveshaft from the donor car (or having a custom one piece driveshaft made). Check with bratsarus1 for his kit to make this easier for you. Link to comment Share on other sites More sharing options...
bratsrus1 Posted September 4, 2010 Share Posted September 4, 2010 Hi This is Jerry, yes i make a 5 speed kit for your car call me and i will let you know what to do 1-509-952-2855. Thanks Jerry Link to comment Share on other sites More sharing options...
Indrid cold Posted September 4, 2010 Share Posted September 4, 2010 +1 for the swap & Bratsrus1 for simplifing the process,.... tis sweet. Link to comment Share on other sites More sharing options...
TomRhere Posted September 4, 2010 Share Posted September 4, 2010 Check the write-ups in here. http://www.indysworld.com/80s/general/USRM/subrepair.htm Link to comment Share on other sites More sharing options...
1982gl4 Posted September 5, 2010 Author Share Posted September 5, 2010 Hi This is Jerry, yes i make a 5 speed kit for your car call me and i will let you know what to do 1-509-952-2855. Thanks Jerry/QUOTE] Sweet deal! What would be a good time to call and what timezone do you live in? I live in live in VT. so I'm in eastern. Also i don't believe I have a flywheel? Does anyone have a flywheel that's the only thing I don't believe i have if not ill just post that i need one in the wanted section. All the scrapyards just crushed all the old subies up here so finding one may be an issue. I can make everything else, and I would buy a new clutch! Link to comment Share on other sites More sharing options...
bratsrus1 Posted September 5, 2010 Share Posted September 5, 2010 Hi This is Jerry, i live in Selah Washington state so i am 3 hours difference 7 am or later is ok with me. Thanks Jerry Link to comment Share on other sites More sharing options...
1982gl4 Posted September 5, 2010 Author Share Posted September 5, 2010 Hi This is Jerry, i live in Selah Washington state so i am 3 hours difference 7 am or later is ok with me. Thanks Jerry/QUOTE] Okay sounds good, I will try and get in contact with you later in the week. Link to comment Share on other sites More sharing options...
edrach Posted September 6, 2010 Share Posted September 6, 2010 EA82 flywheel isn't too hard to find here on the west coast. I may even have one in my "stash." Otherwise, I'm sure someone here can find one for you. You'll find that the holes in the EA82 flywheel are slightly larger. Most people just bolt it down snugly. I bought some brass tubing in 1/32" wall thickness and cut 1/2" lengths and used them as spacers to take up the small gap. Link to comment Share on other sites More sharing options...
doobieryan Posted September 6, 2010 Share Posted September 6, 2010 if you get a flywheel out of an 84 or later ea81 it bolts in just fine and its the size youre looking for. overall much better and easier than ea82 flywheel Link to comment Share on other sites More sharing options...
Gloyale Posted September 6, 2010 Share Posted September 6, 2010 if you get a flywheel out of an 84 or later ea81 it bolts in just fine and its the size youre looking for. overall much better and easier than ea82 flywheel The large EA81 flywheels are thicker than the EA82s. This moves the whole clutch assembly away from the engine, further towards trans. I've seen this combo cause issues where the Throw Out bearing doesn't have enough room to travel away from the Pressure Plate fingers. Doesn't cause problems with every clutch set, but some it does. It really is better to use and EA82 flywheel with the 5 spd. Link to comment Share on other sites More sharing options...
Crazyeights Posted September 6, 2010 Share Posted September 6, 2010 That explains why I had to lengthen the threaded adjustment portion of the clutch cable in order to make my swap work. It does seem to have clearance for the T/O bearing though. Thanks for the info and good luck with the conversion. It makes a HUGE difference. +10 on Jerry's Kit! Link to comment Share on other sites More sharing options...
doobieryan Posted September 7, 2010 Share Posted September 7, 2010 Im just going with what jerry told me when i talked to him about the swap. He said to use the bigger ea81 flywheel and you don't have to worry about the bigger bolt holes and there won't be a harmonic vibration. Link to comment Share on other sites More sharing options...
1982gl4 Posted September 7, 2010 Author Share Posted September 7, 2010 if you get a flywheel out of an 84 or later ea81 it bolts in just fine and its the size youre looking for. overall much better and easier than ea82 flywheel Okay cool because i have a few of those out of my parts brats and other cars! Right now I'm still using the car as my daily driver, so as soon as the snow falls it will be inside getting a five speed for next summer!! Link to comment Share on other sites More sharing options...
1982gl4 Posted September 14, 2010 Author Share Posted September 14, 2010 What clutch would you recommend using? Would one out an ex turbo work? or should I just stick to one out a N/A car like the ea82 GL? This is kind of the only thing holding me up i have most of the other stuff for the swap in a pile already. Also can i mod the 4x4 shift lever assembly to work on the five speed? Link to comment Share on other sites More sharing options...
