porcupine73 Posted September 10, 2010 Share Posted September 10, 2010 The part #'s are all different so I'm not sure. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 26, 2010 Author Share Posted November 26, 2010 next week sometime i'm going to change all 4 struts Im going to leave the strut mounts in place only thing is on like little joint cracks in the road I get this dull metal sound and it's pretty loud at least from listening at the drivers side. I'm not sure if it's the drivers side strut or something else Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 3, 2010 Author Share Posted December 3, 2010 So I'm going to do the struts tomorrow.. because im pressed for time can I just reuse the bump stop until spring? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 3, 2010 Share Posted December 3, 2010 Sure. What do you mean leave the top hats in place? You have to remove them from the car to swap to the new struts. Well maybe you don't HAVE to but it's a lot easier to use a spring compressor when the assembly is off the car. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 3, 2010 Author Share Posted December 3, 2010 Fairtax4me said: Sure. What do you mean leave the top hats in place? You have to remove them from the car to swap to the new struts. Well maybe you don't HAVE to but it's a lot easier to use a spring compressor when the assembly is off the car. I'm talking about the bump stops.. look on page 2 it's so the strut wont bottom out. I had planned to order 4 new today from rockauto but something came up. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 3, 2010 Share Posted December 3, 2010 1-3-2-4 said: next week sometime i'm going to change all 4 struts Im going to leave the strut mounts in place only thing is on like little joint cracks in the road I get this dull metal sound and it's pretty loud at least from listening at the drivers side. I'm not sure if it's the drivers side strut or something else That's what I was talking about. The "Sure" was for the bump stops. Probably don't even need those at all to be honest, but they can be helpful in some extreme situations. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 4, 2010 Author Share Posted December 4, 2010 Well at least we are on the same page now.. From what I understand the strut mounts should have some type of dot or whatever for proper placement? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 4, 2010 Share Posted December 4, 2010 I think they have an arrow or something that points out. The way you know it's right, is if the spring fits correctly. It's only really necessary on the fronts. The rears are easy to see how they go because the top hat is egg shaped. The skinny part goes out. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 4, 2010 Author Share Posted December 4, 2010 I'm not sure where I saw it but they were referring to the strut mounts.. (don't see how it effects anything) to mount the strut that's easy the perch says OUT on it.. it took me so long today because it never got any higher then 38F and plus we had a light wind. I'm hoping Monday I can do the rest of the 3. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 5, 2010 Author Share Posted December 5, 2010 some videos from yesterday So cold in that last video.. Link to comment Share on other sites More sharing options...
