urabus1995 Posted February 23, 2004 Share Posted February 23, 2004 This is a weird one._----I am trying to install a JVC cd/radio unit, which I got given for free. Assured it was working ok. When I switch it on, It makes a whirring sound briefly, shows the JVC logo. then the words "see you" , and switches off. Anyone else had a similar problem? this radio does not need a code, and I am sure that the wiring is Ok. Link to comment Share on other sites More sharing options...
ScoobySchmitty Posted February 23, 2004 Share Posted February 23, 2004 Originally posted by urabus1995 This is a weird one._----I am trying to install a JVC cd/radio unit, which I got given for free. Assured it was working ok. When I switch it on, It makes a whirring sound briefly, shows the JVC logo. then the words "see you" , and switches off. Anyone else had a similar problem? this radio does not need a code, and I am sure that the wiring is Ok. I installed a JVC in my car not too long ago, but I didn't have this problem. Maybe, you got the accessory and regular power wires swapped? See if it works in the ACC position, and if it does, that might be the problem. I'll look up the wire colors for the stereo when I get home. Good Luck! Link to comment Share on other sites More sharing options...
urabus1995 Posted February 23, 2004 Author Share Posted February 23, 2004 Thanks ScoobySchmitty. I did note something a little odd when I looked at the wires on the radio. On the case , it says Yellow is Battery, Red is Accessory. The yellow wire has, running a long its length, litlle negative symbols "-". I am sure that this wire does not connect to -ve on the battery ? the black wire is listed as being ground. The speakers are all in obvious pairs of colours. I think maybe its just a bad unit that I have been given. I will have another look tonite when I get home. Cheers,John Link to comment Share on other sites More sharing options...
ScoobySchmitty Posted February 24, 2004 Share Posted February 24, 2004 Ok, sounds good. my only question is whether or not you have the wiring diagram for the scoob? Instead of purchasing the wiring harness, I simply cut (!) the connector for the OEM radio, and simply matched up the wires, based on the wiring diagram for the JVC, and the wiring diagram for the OEM radio. It works great From what I have learned, it seems that most all radios have a common ground, and it is universally the black wire. The little dashes on the yellow wire should mean "yellow/black". Are you sure it is not one of the speaker wires?? Check out the wiring again, hopefully it's just a simple mixup. Good Luck! Link to comment Share on other sites More sharing options...
Porter Posted December 4, 2004 Share Posted December 4, 2004 and simply matched up the wires, based on the wiring diagram for the JVC, and the wiring diagram for the OEM radio. It works great You have the wiring diagram for the stock radio? I'm in the process of wiring up an STi head unit into a '90 Legacy. Post that sucker up if you have it! Link to comment Share on other sites More sharing options...
Porter Posted December 4, 2004 Share Posted December 4, 2004 LOL nevermind... Found it! http://www.graphics.cornell.edu/~v/bcstereo/ Link to comment Share on other sites More sharing options...
coloradosubarules Posted December 4, 2004 Share Posted December 4, 2004 I would always reccomend using an aftermarket wiring harness. If your OEM harness is hacked I would reccomend going to a salvage yard and picking up one and splicing it in and then going to your local stereo shop or best buy and buying the matching harness. It makes it all simple. Link to comment Share on other sites More sharing options...
