I Just put in a pushbutton and figured I would share how I did it! Its a fun way to replace a non-functioning key switch and you kind of feel like your firing up the millennium falcon when you start your soober! If you look at the diagram I have drawn up you'll see that I used 3 toggles and a momentary button all rated to handle at least 20amps. I cut the wires off of the existing switch, stripped them all back and crimped ring terminals to each wire. two of the switches and the momentary bu
