92_rugby_subie Posted September 8, 2010 Share Posted September 8, 2010 1991 Legacy Sedan Ej22 engine What exhaust optins do I have? Can I but an STI muffler on it? I thought about doing cut-outs with an STI exhaust system, but I dont want something that is gonna be an impossible project... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 8, 2010 Share Posted September 8, 2010 (edited) STi muffler will sound like crap on the EJ22. From experience I can tell you it's bad..... makes people around your car feel like vommiting. If you want it to be louder - knock the muffler off and replace it with a straight-through. The EJ22 doesn't have the cams or the displacement for the STi muffler to sound right. It will sound horrible. Like a tiny engine with a gigantic exhaust (weak and tinny). You don't need to upgrade the exhaust at all until you are well into higher HP numbers. The stock exhaust is plenty for the EJ22 and frankly even a mildly built EJ22 or a stock EJ25 would be fine. GD Edited September 8, 2010 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 8, 2010 Author Share Posted September 8, 2010 Is that gonna cause issues for DEQ when it needs tags? Quote Link to comment Share on other sites More sharing options...
snowscooby Posted September 9, 2010 Share Posted September 9, 2010 I would have to think straight pipe would make it harder to pass emissions. If you are looking for a nice sound there are lots of aftermarket options (cat-back). Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 9, 2010 Author Share Posted September 9, 2010 Thats what I was thinking was a cat-back system with cutouts (so its quiet when I get home, having had a Mitsubishi with a custom exhaust and my mom getting mad when I pulled into the street and made noise) Quote Link to comment Share on other sites More sharing options...
snowscooby Posted September 9, 2010 Share Posted September 9, 2010 I run a cat-back borla system on my impreza and it is super quiet at low rpms. I really like the sound of it. However it was about 600$ new so that kinda sucked, I would suggest looking into similar systems and see what you find. The tip design helps a lot (I have never seen a tip shaped the same way) at keeping the sound down. Its 3 inches tapered down to about 2 or so where it meets the actual muffler. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 9, 2010 Share Posted September 9, 2010 Unless its rusting apart, don't waste your money, you've got 135 horse, a muffler isn't going to change anything, except make you more visible to the local constabulary. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 9, 2010 Share Posted September 9, 2010 (edited) Unless its rusting apart, don't waste your money, you've got 135 horse, a muffler isn't going to change anything, except make you more visible to the local constabulary. +1. Huge waste of money. It will not affect DEQ to put any kind of exhaust on as long as you retain the header with the y-pipe and cat. Anything beyond that will just change the sound. I'll just put this out there since you seem to be very concerned about being able to mod your new Legacy: There is basically NOTHING that is cheap or easy to upgrade on a first-gen EJ22 Legacy. It is what it is - the best bang for your buck is to buy cams from Delta for $160 and install them along with a new timing belt, water pump, and reseal. They are easy and the torque cams WILL make a big difference. Beyond that - you are looking at about $1000 minimum to get into a 2.5 block or get a start at turbo-charging it. Frankly that car isn't worth it. The body is trashed. It's a nice cheap commuter. You should just leave it be and let it be reliable and cheap for you. When you have money you should START by buying a different car that has actual performance potential and has decent looks to go with it. Something with a turbo would be a good start. GD Edited September 9, 2010 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 9, 2010 Author Share Posted September 9, 2010 I have realized it will be expensive. I just want somethings to set my car apart from others.... and the main thing to do (at least at my age) is: - Rims - Exhaust - Sound - Performance - Lights Etc. Since this car only has 130k (and Im anal about maintenance) I imagine that this car should get me another 100k+ miles, and so since Ill have it at least 5 years, I will want a stereo (this one doesnt work) and Ill want an exhaust, rims probably wont happen, I wanna get rid of the ones that were on it and get ones that I know are stock on some Subaru (Finally have 5 lugs which Ive never had) and smoking the lights is another interest... I want something that people will know its me coming, all my Subarus have had distinct sounds, but this one just sounds plain, maybe the muffler on it, I have no idea. I dont want a teeny bopper right at all, no body kits, no huge ricer exhaust (fart can) I just want something that sounds real and looks semi cool. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 9, 2010 Share Posted September 9, 2010 I have realized it will be expensive. I just want somethings to set my car apart from others.... and the main thing to do (at least at my age) is:- Rims - Exhaust - Sound - Performance - Lights Etc. Since this car only has 130k (and Im anal about maintenance) I imagine that this car should get me another 100k+ miles, and so since Ill have it at least 5 years, I will want a stereo (this one doesnt work) and Ill want an exhaust, rims probably wont happen, I wanna get rid of the ones that were on it and get ones that I know are stock on some Subaru (Finally have 5 lugs which Ive never had) and smoking the lights is another interest... You won't be smoking any lights unless the subie is 2wd, and if it is its not really a subaru is it? I want something that people will know its me coming, all my Subarus have had distinct sounds, but this one just sounds plain, maybe the muffler on it, I have no idea. The Police will take an extra special liking to your car if its unique and has chrome rims, Police do profile. I dont want a teeny bopper right at all, no body kits, no huge ricer exhaust (fart can) I just want something that sounds real and looks semi cool. Semi cool is a matter of opinion, I would think most here would think you're making your car teeny bopper whether you see it or not. I'm not here to poop on your Popsicle, sure a nice stereo is a good thing to have, and you can get newer subie rims on craigslist for really cheap, but lights will get you pulled over and a loud exhaust will too. Just be aware of your state laws on lights and exhaust and you'll be fine. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 9, 2010 Author Share Posted September 9, 2010 Thats why I want the cutouts I can be quiet when they are closed. I saw one on Google Images that had smoked tail-lights.... is that illegal? They looked pretty awesome... I will upload pics of the rims I want and the look of the lights that I want. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 9, 2010 Author Share Posted September 9, 2010 Wheels I want : What they look like (not my car) The smoked taillights: Maybe the exhaust too? Saw these pictures on google, a guy called "Kandyman" does anyone know him to be on a Subaru board? Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 9, 2010 Share Posted September 9, 2010 I saw one on Google Images that had smoked tail-lights.... is that illegal? Very much yes, they will get you pulled over. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 10, 2010 Author Share Posted September 10, 2010 Then I shall not put any smoked lights on the Subaru I dont wanna attract attention and get a ticket for something so miniscule. Quote Link to comment Share on other sites More sharing options...
Seantheimpaler Posted September 10, 2010 Share Posted September 10, 2010 What you aught to do is put a loudspeaker on it! then you can just yell through it while yer rollin down the road! they'll know yer commin:lol: Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 10, 2010 Author Share Posted September 10, 2010 Eventually ill have a PA system Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 10, 2010 Share Posted September 10, 2010 Eventually ill have a PA system Also illegal I had one on a past Subie, be careful when you use it. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 10, 2010 Author Share Posted September 10, 2010 Really? I know several friends that have them, but then again, they also have semi and train horns so I guess they are just dumb haha. Quote Link to comment Share on other sites More sharing options...
snowscooby Posted September 10, 2010 Share Posted September 10, 2010 Just move to washington! All of my friends in my town have PA's, exhausts, and flashy lights. The only thing that seems to be an attention getter (at least in my town ((for the cops))) are the fake blue hid lights. Just read up on your laws to see what you can do. Keep it classy and people will recognize you. I found that converting my body styling from a 1997 impreza L to a 2.5rs with 22b vents actually turns quiet a few heads. There are plenty of things you can do that are fun, teach you a lot about cars, and legal. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 10, 2010 Share Posted September 10, 2010 Leave it bone stock except the engine - be like the Ninja - silent but deadly. Don't let your enemies know you are comming. GD Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 10, 2010 Author Share Posted September 10, 2010 I like that, hehe sleeper cell? Lol. Fix it up, make it look like a granny car and then pounce on the Honda Quote Link to comment Share on other sites More sharing options...
Manarius Posted September 11, 2010 Share Posted September 11, 2010 I had a 1991 Legacy at your age, a few more miles though (155k at that point). I think the best upgrade for that car is WRX rims. They fit just right and are larger than stock (16 vs 14). The rims you mentioned are 15's that come on the Turbo Legacy or mid-90's Outbacks. (Those are also 1991 Legacy SS's-turbos, they have about 160hp) Quite frankly, without a turbo, the only thing you can do to make the car sound good is go with a straight pipe or just some resonators with no muffler. I don't know the laws in your state but if you don't have emissions (I know Indiana does not have inspections) you could get away with making decent noise. Driving/Fog Lights are a good idea too. The stock headlamps are terrible (even when cleaned), so having some aux lights helps. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 11, 2010 Share Posted September 11, 2010 Quite frankly, without a turbo, the only thing you can do to make the car sound good is go with a straight pipe or just some resonators with no muffler. Cams - helps with the sound too and probably the quickest, easiest, cheapest way to get more power. For $160 and some seals you can increase your torque by a considerable amount. GD Quote Link to comment Share on other sites More sharing options...
