Subaru "Harvester"
TommyH
About a year ago i bought this this -91 mpfi 5spd d/r Leone for 40€ ( about 51usd).
Unfortunately i found out that engine wont fit my Legacy, so...
Hatch? Pick-up? nah... too big overhangs ;)
2" lift, 6lug conversion and 33" at's for winter and 225/75-15 baldies for summer (I'm trying to find better tires)
Long travel (stock) suspension ;)
Found some practical use for subbie...
Some short clips...
Allmost forgot...
(edit: Fixed the last video link)
Edited by TommyH
I'm glad that you like it. :)
monstaru: I'm from Finland. That car is just my daily driver. Opel Omega, German cop car replica ;)
uberoo: Cooling system is maby the only thing that can be moved back for now. I'm going to install a Suzuki Sj410 t-case with 3" lift and try to move front and back subframe forward 4-8 inches and engine couple of inches back. That should move the center of gravity. Also rollcage and bigger gas tank (25L -> 75L) will help.
Scott in Bellingham: At earliel pictures its a stock subaru radiator. Latest radiator is from Vw Golf mk2 1,3C with radiator cap fitting from Yamaha Exciter 2 (snowmobile) :)
Has anyone done t-case install with 3" lift? Project pics would help. I'm wondering about front diff and engine placement...
Edited by TommyH
  • 4 months later...
Time to update front suspension. I'm trying to fit Lecacy hubs and shocks (2wd BACK shocks).
Here is Ej18 2wd front(lower in picture) and back shocks.
Back shocks seem to have 2" more travel than front at 8,8" of travel :)
Planning to run on 12" wide 27" ATV tires with redrilled rims. Only 10" wide 25"'s in picture.
Made some 5*100 -> 6*139,7 adapters :)
Lots of clearance :)
Btw. Does the 2wd inner joints fit ea tranny? or do i have to fabricate custom shafts....
Edited by TommyH
  • 2 weeks later...
  • 2 weeks later...
  Uberoo said:
I recommend hood pins so you hood doesn't fly up and smash whats left of your windshield.:brow:
with no window you could just wear ski goggles though...
Awesome video through!
Hood didn't leave a mark on the windshield. Fortunately hood is so flimsy with that hole in the middle ;) There is rubber hood straps trying to keep hood closed. Next time i might remember to hook them properly :)
...btw the windshield is a nice accessory driving around at -25 degrees Celsius (-13 degrees Fahrenheit) ;)
