87 RX window issues
My passenger window on the RX won't roll back up. I've tried to bypass the switch, and nothing from the motor. Not even a click.
I am fairly sure the motor finally gave up. Been slow for years.
What I need to know is if there is a way to manually get the window back up, and stay up without taking out the frame bolts?
Hi, if you unplugged the motor from inside the door wiring harness and used 12v directly to the motor connector , it should go , if not the motor is bad. i just had the same thing on my xt, after a lot of trial and error i had to put in another motor assembly. as far as getting the window up i don't think any way other than to unbolt it and slide it up, maybe able to wedge it in the up position some way till you get another motor assy.
