86GLScooby Posted September 13, 2010 Share Posted September 13, 2010 Hi, I'm replacing the head gaskets on my legacy GT and I have everything removed to where I can access the head. Timing belt off and intake manifold off. Can I push the car back like this and then pull it up again to continue work once the parts get here? Need to use that part of my shop... It's in neutral, so I don't see why not, but they say not to move the car while working on it. Thanks. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 13, 2010 Share Posted September 13, 2010 Is the engine still in the vehicle? If it's still mated to the trans I don't think there's much risk in moving it a few feet. Esp if it's an MT just have her in neutral. An AT can be rolled a short distance. If the engine is removed I'd just make sure there's no components that could drop off during the rolling, like having say the torque converter fall off would be bad just as an example. Not that it would just fall off but it's those little details that always bit us. The risk in rolling if the engine is still installed I'm thinking would be if for some reason the crank rotates you might end up bumping the pistons into the valves. Quote Link to comment Share on other sites More sharing options...
86GLScooby Posted September 13, 2010 Author Share Posted September 13, 2010 Yeah, i need to move it 6 feet... it's an AT with engine in car. I really don't want the crank to rotate any... I'll see what I can do around it. Thanks Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 13, 2010 Share Posted September 13, 2010 Thee auto really shouldn't rotate the crank when rolled since there's no line pressure to activate any of the clutches anyway. If you can find the access cover for the flywheel you might be able to jam a small prybar or something in there just to be on the safe side. Here's a pic of something jammed in there but it is on a 2.2L: Quote Link to comment Share on other sites More sharing options...
Hocrest Posted September 13, 2010 Share Posted September 13, 2010 With the car in Neutral, push it all you want. The crank will stay exactly where you left it. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 13, 2010 Share Posted September 13, 2010 yes you can move it paying attention of course. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 13, 2010 Share Posted September 13, 2010 Very simple. Put trans in neutral, remove all tools/screws/bits that can fall and get lost or lodged in a tire, push car. Like porcupine said, neutral on an auto trans is just like neutral in a manual, it'll free spin no problem. You could even put it in drive or reverse if you want. No line pressure (the pump isn't turning) means none of the clutches or bands will be engaged so no transfer of motion from the output shaft to the input shaft. And at that, if there is any, the torque converter won't transfer any movement of the input shaft to the flywheel anyway. Not at Fred Flintstone style propulsion speeds at least. Quote Link to comment Share on other sites More sharing options...
