sario Posted September 14, 2010 Share Posted September 14, 2010 (edited) I've had a two problems develop with in a week of each other. The first is a shudder at low speeds, right before the car shifts to second gear. Other wise it runs fine. All the vacuum lines appear to be connected. The second is the occasional ping sound when I back up in reverse, and sometimes when I put it in drive right afterward. Any help appreciated! And in case it's relevant.... 1997 Legacy Outback 2.5L Auto 226,000 miles King springs throttle body bypass. No CEL Edited September 15, 2010 by sario Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 14, 2010 Share Posted September 14, 2010 Hm.....just throwing this out there on a whim, did you happen to have either front axle replaced lately? Quote Link to comment Share on other sites More sharing options...
sario Posted September 14, 2010 Author Share Posted September 14, 2010 Hm.....just throwing this out there on a whim, did you happen to have either front axle replaced lately? I didn't even think about that! I did reboot one about 10,000 miles ago. I have no clue how long it was torn before i noticed it. What’s the best way to check one of those? Just wiggle it around and see if its loose? Quote Link to comment Share on other sites More sharing options...
sario Posted September 15, 2010 Author Share Posted September 15, 2010 I crawled under the car before driving home work and the axles appear...... fine. The shudder happens right around 1900 to 2200 rpms. I think its there even when in neutral. It's definitely worse starting out on a hill. Quote Link to comment Share on other sites More sharing options...
sario Posted September 15, 2010 Author Share Posted September 15, 2010 Hm.....just throwing this out there on a whim, did you happen to have either front axle replaced lately? Well porcupine, i think you are probably right. So i'm going to order a MWE axle and see if that solves the problem. Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 Ok. it's still there with a new axle. The shudder feels like somethings loose in the drive train. But I cant find anything, and all the bushings appear to be in good shape. HELP??? Quote Link to comment Share on other sites More sharing options...
nipper Posted October 3, 2010 Share Posted October 3, 2010 Any CEL? Recent Maint history on the car? Does the car push through the shudder or does it affect performance? Any flashing lights on startup? Does it happen at a shift-point? WHat happenes if you manually shift the car? Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 (edited) Any CEL?Recent Maint history on the car? Does the car push through the shudder or does it affect performance? Any flashing lights on startup? Does it happen at a shift-point? WHat happenes if you manually shift the car? Recent Maint history on the car? In the last 4,000 miles New battery Rebooted a axle then the same axle was replaced 5,000 miles ago. engine removed so oil the pan seal could be replaced. Does the car push through the shudder or does it affect performance? it pushes right through it, and there is no performance loss i can tell Any flashing lights on startup? None Does it happen at a shift-point? yes. Only at the end of first gear, right before it shifts to second. It only happens in first gear. it IS worse starting on a hill WHat happenes if you manually shift the car? I'll have to let you know that one tomorrow. Edited October 3, 2010 by sario Quote Link to comment Share on other sites More sharing options...
nipper Posted October 3, 2010 Share Posted October 3, 2010 DO the manual shift thing and drive past the RPM where the problem occures. Shift below it, at it, and above it and let me know what happens. How long has the car been doing this? Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 DO the manual shift thing and drive past the RPM where the problem occures. Shift below it, at it, and above it and let me know what happens. How long has the car been doing this? About two weeks. I'll go for a drive now. I'll let you know it Ten. Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 DO the manual shift thing and drive past the RPM where the problem occures. Shift below it, at it, and above it and let me know what happens. If i start out in second i CAN feel it there. If i shift to second before it hits 1800 i don't think i can feel it. If you shift at it, it goes away. shifts just fine above it Quote Link to comment Share on other sites More sharing options...
nipper Posted October 3, 2010 Share Posted October 3, 2010 Start with flusshing the fluid. FLushing forgives all sins in a sooby. How many miles again? Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 Start with flusshing the fluid. FLushing forgives all sins in a sooby. How many miles again? 227,000. I change the fluid about every 15,000 miles(drain and refill). Do you mean i should have a power flush done at mechanic shop? Quote Link to comment Share on other sites More sharing options...
nipper Posted October 3, 2010 Share Posted October 3, 2010 227,000. I change the fluid about every 15,000 miles(drain and refill). Do you mean i should have a power flush done at mechanic shop? Respond to this fro me so i get emailed on it, but it is late, my brain is fried, lets pick this up tomorrow Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 Ok i'm heading down to drop the transmission pan now. I'll try that first Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 Respond to this fro me so i get emailed on it, but it is late, my brain is fried, lets pick this up tomorrow Ok the fluid is changed. No luck. Quote Link to comment Share on other sites More sharing options...
chef_tim Posted October 3, 2010 Share Posted October 3, 2010 Give the U-joints a wiggle too. Not a real common problem with Subs but they do wear out. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 3, 2010 Share Posted October 3, 2010 You did not have to drop the pan, sometimes that just makes things worse. This may have nothing to do with it, but put the FWD fuse in and report back. Quote Link to comment Share on other sites More sharing options...
sario Posted October 3, 2010 Author Share Posted October 3, 2010 (edited) Give the U-joints a wiggle too. Not a real common problem with Subs but they do wear out. They seem fine. But i've been thinking about taking them off to get a better look. Thanks for the ideal You did not have to drop the pan, sometimes that just makes things worse. This may have nothing to do with it, but put the FWD fuse in and report back. I'm going to have check that in a day or two. A local guy is making a front bumper to replace the one that got tore off on a bad road. I hope you all are still be available to help then. Thanks Edited October 3, 2010 by sario Quote Link to comment Share on other sites More sharing options...
nipper Posted October 4, 2010 Share Posted October 4, 2010 I hope you all are still be available to help then. Thanks I'm planning on still being on the planet for a while, so just add to the post and i will perk up. Quote Link to comment Share on other sites More sharing options...
sario Posted October 13, 2010 Author Share Posted October 13, 2010 Well the problem went from all-the-time to intermittent. :-\ That’s why I haven’t been bumming for help. I'm going to try replacing the other front axle. It's an OEM remanufactured that's been in there for about 30,000 miles. I really doubt it's the problem, but I’m not sure what else it could be. If the problem goes back to being consistent I’ll try the FWD fuse. Quote Link to comment Share on other sites More sharing options...
Dickensheets Posted October 23, 2010 Share Posted October 23, 2010 I had a bad shudder in my 97 3yrs ago same as you describe. New ignition wires cured it. Ryan Quote Link to comment Share on other sites More sharing options...
sario Posted October 23, 2010 Author Share Posted October 23, 2010 I had a bad shudder in my 97 3yrs ago same as you describe. New ignition wires cured it. Ryan I'll put that on my list to try. thanks Quote Link to comment Share on other sites More sharing options...
sario Posted November 12, 2010 Author Share Posted November 12, 2010 Well the problem went from all-the-time to intermittent. :-\ That’s why I haven’t been bumming for help. I'm going to try replacing the other front axle. It's an OEM remanufactured that's been in there for about 30,000 miles. I really doubt it's the problem, but I’m not sure what else it could be. If the problem goes back to being consistent I’ll try the FWD fuse. We'll the problem came back, worse than before. So i put the FWD fuse in, and it seemed to disappear. I guessed that nippers test was suggesting the \ drive line so i gave it another look. After pulling the exhaust off i found a broken transmission mount. The problem is found and fixed now Thanks for everyone’s help! Quote Link to comment Share on other sites More sharing options...
