86subaru Posted September 19, 2010 Share Posted September 19, 2010 drained filled drained filled tranny changed filter, 160,000mi on it a/t , after sitting all nite it shifts good but shifts alittle hard first time after that good, should i drain fill it again but use royal purple , ansoil , or = to it , thinkin it might help ,any suggestions ? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 19, 2010 Share Posted September 19, 2010 The only thing I've heard reccomended is the Trans-X that can sometimes help with torque bind. I wouldn't use anything but plain Dexron ATF myself. Some of the 4EAT's shift a little hard - just their nature I think. I've never seen that it's a sign of impending failure though. GD Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 19, 2010 Author Share Posted September 19, 2010 thanks, Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 20, 2010 Share Posted September 20, 2010 Do you mean it is slow to engage into drive after sitting all night? And/or do you mean that first 2-3 upshift seems like it 'slips'? Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 20, 2010 Author Share Posted September 20, 2010 yes. but after that it is fine sitting 10-12 hrs at work, Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 20, 2010 Share Posted September 20, 2010 The '99 model year 4EAT's have a problem with delayed engagement. There's a seal you can replace, or you can try the trans-x additive and see if that helps. At any rate it's not that big of a deal. GD Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 20, 2010 Author Share Posted September 20, 2010 well tried it , drained filled tranny again and seemed to help alot, will tell more in the morning, [ used x tranny stuff] Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 20, 2010 Share Posted September 20, 2010 If you get the 2-3 blip on the first upshift after sitting overnight, that's a known characteristic of the phase II 4EAT. Something about the hydraulic circuit bleeding down. The delayed engagement into drive can be a more serious issue as noted above. Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 20, 2010 Author Share Posted September 20, 2010 it is just the up shift delay. thanks Quote Link to comment Share on other sites More sharing options...
Gloyale Posted September 20, 2010 Share Posted September 20, 2010 Castrol makes a very good ATF for "imports- Honda, Nissan, Toyota" is how it's labeled. (All of those makers and subaru's Auto trans come from same manufacturer, Unisia? I believe) That is the ATF I've had the best luck with in subaru. Espescially the phase II trans. A bottle of "Trans-x stop slip" is good for them too. Get's rid of the delayed engagement/hard shift. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 20, 2010 Share Posted September 20, 2010 Now that GM doesn't license the good 'ol Dexron II/III blends anymore the 'multi vehicle' seems to be the one a lot of people are using. I'm not sure who is making Subaru's transmissions, at least from that era? I know for some years Nissan and others were using what people call 'J boxes', which are made by jatco.co.jp Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 20, 2010 Author Share Posted September 20, 2010 ok, thanks Quote Link to comment Share on other sites More sharing options...
Gloyale Posted September 21, 2010 Share Posted September 21, 2010 Yeah, it's Jatco.......I don't know why I thought Unisia. But yeah, Jatco makes basically all the Japanese Import trannies, so fluid for say a Nissan or a Honda should and does (in my experience) work well for the Subaru trans. Works well for the Power Steering pump too. Quote Link to comment Share on other sites More sharing options...
