I have a 90' Subaru legacy front wheel drive. My rear bearing is ready to be change and I was looking for a bearing on eBay , but I'm not sure whats the part #. They have a couple for four wheel drive, but I don't know if it is the same fit. If anyone knows the part #??? it would help alot thanks
Hm that one is tricky, none of the Subaru dealer sites seem to list that one.
Some info I found showed TIMKEN Part # 512036 Ball Bearing; 3.937 in. Bolt Circle Diam; 4.960 in. Flange Diameter; 2.539 in. Flange Offset; 56 mm Wheel Pilot Diam FWD; Non-ABS; Rear
Looks like it is the hub and bearing together as a unit; I'm assuming that's because it is FWD.
