blass001 Posted September 19, 2010 Share Posted September 19, 2010 I have a 90' Subaru legacy front wheel drive. My rear bearing is ready to be change and I was looking for a bearing on eBay , but I'm not sure whats the part #. They have a couple for four wheel drive, but I don't know if it is the same fit. If anyone knows the part #??? it would help alot thanks Link to comment Share on other sites More sharing options...
Manarius Posted September 19, 2010 Share Posted September 19, 2010 I searched the OEM catalog, I can't even find a wheel bearing for non-4wd. Link to comment Share on other sites More sharing options...
blass001 Posted September 20, 2010 Author Share Posted September 20, 2010 That might mean that iit's the same part for 4wheel and 2 wheel drive?? Link to comment Share on other sites More sharing options...
porcupine73 Posted September 20, 2010 Share Posted September 20, 2010 Hm that one is tricky, none of the Subaru dealer sites seem to list that one. Some info I found showed TIMKEN Part # 512036 Ball Bearing; 3.937 in. Bolt Circle Diam; 4.960 in. Flange Diameter; 2.539 in. Flange Offset; 56 mm Wheel Pilot Diam FWD; Non-ABS; Rear Looks like it is the hub and bearing together as a unit; I'm assuming that's because it is FWD. Link to comment Share on other sites More sharing options...
NorthWet Posted September 20, 2010 Share Posted September 20, 2010 Bad news: 90 FSM: "The hub and bearing are combined as a unit and cannot be disassembled." So, although you can remove the hub from the spindle, it looks like all you can do is replace the hub. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 20, 2010 Share Posted September 20, 2010 A used hub/spindle is probably your best bet. Check www.car-part.com I've found some great deals through there and usually you can find a local option if you want to avoid shipping, etc. Excelent resource. GD Link to comment Share on other sites More sharing options...
Gloyale Posted September 20, 2010 Share Posted September 20, 2010 Hub/Bearing assembly replace as unit......super easy http://www.autozone.com/autozone/parts/1992-Subaru-Legacy/Wheel-Bearing-Hub-Assembly-Rear/_/N-iwzflZ6o2nz?filterByKeyWord=rear+hub&fromString=search Link to comment Share on other sites More sharing options...
blass001 Posted September 20, 2010 Author Share Posted September 20, 2010 That's not cool! I guess it will be easier to install that way. Thanks guys i appreciate your help Link to comment Share on other sites More sharing options...
