More on Frozen Engine
kb7chd
Hello. Thanks for the help on my frozen engine which is still frozen. Another concern I have, however, is that the car was towed with all four wheels on the ground for eleven miles. This according to the guy I bought it from. My Haynes manual says this car cannot be towed more than six miles! I assume this means the transmission is ruined also. If so, I am wondering if it is worth messing with this thing. I would have to replace the tranny and the engine. I paid $400 for the car. The body is straight and the interior is clean. It would be a nice car but... Any thoughts
As long as it was not towed above say 40mph, it should be ok. What happens is the trans pump isn't running so there's no fluid going to the bushings/bearings and as a result the burn up when being towed. I've towed autos father than that (stop and go) and kept the speed down and they were fine.
Thanks for the comments. Still trying to free the engine by putting penetrating fluid (Free All) in each cylinder and using a two foot pipe wrench, with a four foot pipe extension, on a socket on the crankcase bolt. Nothing yet, and I have not broken the socket, and I will keep at it the next few days. Would it help maybe to fill each cylinder with diesel or something?
More to the point on the 4wd automatics, the rear-transfer function is performed by a clutch pack, where half the plates will be rotating with the rear wheels and the other half will be affected by plate drag w/o lubricant... maybe turning some, maybe not. Speed and distance matter, but I have abused a 3AT at 55mph for 40 miles and it still worked.
I'm restoring a '56 Chrysler that sat in the dirt in my grandpa's barn for 40 years. Engine was blown when it was parked and had been rusting since(the oil pan was filled with tar like goo that used to be oil). I pulled the engine and filled each cylinder with diesel fuel until in spilled out the spark plug hole or out the exhaust. I checked on it every week or so to see if I could break it free, finally after 8 months it did. I guess I'm saying that the diesel should work for you depending on how stuck it is because my engine was about as bad as it could get.
He said the car was flat towed, all 4 on the ground. So in that case there should have been minimal movement between the 2 sets of plates. Both should have been spinning the same amount except for the differnence in turning.
Thanks, I missed the "flat tow" part. My comment was more for a tow dolly situation.
