Durania Posted September 29, 2010 Share Posted September 29, 2010 95 Outback. Just wanting to do some preventative maintenance. What are the grease points on the clutch cable system? I know on my BRAT it helped if I kept the pedal lubricated. Thanks. -Kyle Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 29, 2010 Share Posted September 29, 2010 The only major one is on the release lever pivot bolt inside the bell housing. The rest of the cable system doesn't move much except for the cable itself, and you can't lube that. I suppose you can hit the pedal pivot with some lithium grease. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 29, 2010 Share Posted September 29, 2010 Yeah - pretty much the pedal pivot point is all that's accesible. The cable is dry-lubed and if that is comprimised the best solution is just to replace it for $25 GD Quote Link to comment Share on other sites More sharing options...
Durania Posted September 29, 2010 Author Share Posted September 29, 2010 Thanks for the replies. The cable is fine though. Quote Link to comment Share on other sites More sharing options...
