Scholzpdx Posted September 29, 2010 Share Posted September 29, 2010 94 Impreza 1.8 L Sedan 210K Well, as title states. What voltage or ohms should those sensors be putting out? My dad needs to know before we start replacing them. Also I did tow my car home for one mile, but it was in neutral and it was a straight pull, not towed up onto a truck or anything like that. My only problem is that since that happened my back lights wont shut off. Even when I turn off my car those lights stay on. Any ideas? Are they correlated? Previous thread here: http://www.ultimatesubaru.org/forum/showthread.php?p=950000 Link to comment Share on other sites More sharing options...
porcupine73 Posted September 29, 2010 Share Posted September 29, 2010 When you say your back lights do you mean your reverse lights? I'm not sure about those. But if you mean the parking lights are staying on, check that switch on top of the steering column, maybe it got bumped on during the towing. The cam and crank position sensors you really need a scope or an analog type meter to check the pulse. Looks something like these (cam may vary somewhat depending on the reluctor marks on the back of the cam sprocket) Link to comment Share on other sites More sharing options...
Scholzpdx Posted September 29, 2010 Author Share Posted September 29, 2010 They are the Red lights, I believe these two. I'm about to be going over to my parents place where it's sitting. Not my car, obviously, but those two. Other people with somewhat similar problems think its the MAF or maybe even the ECU. Does my problems how i described in the other thread sound like the crank is it? I already replaced the cam sensor. Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 29, 2010 Share Posted September 29, 2010 (edited) FSM for 95 says Crank/cam angle sensor resistance values should be between 1-4 KΩ. I can't imagine they're much different from 94 to 95. Not sure about the lights. Are those the brake lights? (not sure which are which on the Imp) Edited September 29, 2010 by Fairtax4me Link to comment Share on other sites More sharing options...
johnceggleston Posted September 30, 2010 Share Posted September 30, 2010 They are the Red lights, I believe these two. I'm about to be going over to my parents place where it's sitting. Not my car, obviously, but those two. Other people with somewhat similar problems think its the MAF or maybe even the ECU. Does my problems how i described in the other thread sound like the crank is it? I already replaced the cam sensor. check the VIRGIN SWITCH on top of the steering column. it leaves the parking lights on when you turn the key off so you can park your car on country roads in foreign countries and not have your car run into. also is a great way to meet other subaru enthusiast when you have to go online and ask for help about "how do i turn off my parking lights?" Link to comment Share on other sites More sharing options...
