1-3-2-4 Posted September 30, 2010 Share Posted September 30, 2010 question where can I connect a gauge up to check? Link to comment Share on other sites More sharing options...
OB99W Posted September 30, 2010 Share Posted September 30, 2010 1-3-2-4 said: question where can I connect a gauge up to check? As close to the center of the intake manifold as possible. On the EJ engines, that usually means a connection just to the front of the throttle body. Be sure to use a "T" so that whatever was connected there still gets vacuum while the gauge is connected. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 30, 2010 Author Share Posted September 30, 2010 I should have a T fitting not sure if it will fit. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 3, 2010 Author Share Posted October 3, 2010 i have't got to this yet since a death in the family but I'm pretty sure a gasket is gone on the inake manafold that mates to the engine.. don't hear it at idle but if you hold it around 2K you hear this air.. But my PS pump is also leaking but I doubt I'd have that hiss. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 6, 2010 Author Share Posted October 6, 2010 I just came from outside.. my hose is a little too big in the I/D but I took the hose off on the L shaped vacuum hose just after the T/B and I got no reading until I revved the engine.. if I did the hose where the FPR was I got a good reading. Maybe I used the wrong location? Link to comment Share on other sites More sharing options...
OB99W Posted October 6, 2010 Share Posted October 6, 2010 1-3-2-4 said: I just came from outside.. my hose is a little too big in the I/D but I took the hose off on the L shaped vacuum hose just after the T/B and I got no reading until I revved the engine.. if I did the hose where the FPR was I got a good reading. Maybe I used the wrong location? You obviously first connected to a source of ported vacuum. What you want is a connection on the intake manifold, to the front of the TB. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 6, 2010 Author Share Posted October 6, 2010 Does the FSM shows where various ports are? From my understanding it should be as close and to the center as possible but haynes just shows it connected to the intake port for cyl #3 Link to comment Share on other sites More sharing options...
OB99W Posted October 6, 2010 Share Posted October 6, 2010 Can you post a pic of the intake manifold, near the TB? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 6, 2010 Author Share Posted October 6, 2010 here you go the only lines I see is were the brake booster and the FPR Link to comment Share on other sites More sharing options...
OB99W Posted October 6, 2010 Share Posted October 6, 2010 1-3-2-4 said: here you go the only lines I see is were the brake booster and the FPR There's the PCV, too. Looks like you'll have to "T" into the FPR vacuum line, since I doubt you'd want to drill and tap the manifold. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 6, 2010 Author Share Posted October 6, 2010 Looks like I should do the spark plug test instead? The pvc should work too right? I think mine is due for a replacement soon Link to comment Share on other sites More sharing options...
OB99W Posted October 7, 2010 Share Posted October 7, 2010 1-3-2-4 said: Looks like I should do the spark plug test instead? The pvc should work too right? I think mine is due for a replacement soon I thought we were discussing the connection of a vacuum gauge. If there's more that this is related to, you'll need to be specific. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 7, 2010 Author Share Posted October 7, 2010 In your last post you said there is also the pcv. A question I have is the port for the fpr is it for all cylinders? Link to comment Share on other sites More sharing options...
OB99W Posted October 7, 2010 Share Posted October 7, 2010 Using the PCV connection isn't practical, hence the ";)". As we've discussed, the best place to measure vacuum is at a central location on the intake manifold. Sometimes that isn't a choice. Since the FPR needs to know how "all cylinders" are doing, even if the point isn't ideal, it's adequate for your needs. The main difference the vacuum take-off point on the intake manifold will make in the measurement is that a central point tends to average it better -- that is, there's less pulsation. If you see more needle vibration than you'd like, you can dampen the movement by restricting the flow. That can be done with an orifice in the gauge's vacuum line, or something as simple as pinching the hose. Just be sure the needle movement isn't indicating an actual problem before you damp it out. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 7, 2010 Author Share Posted October 7, 2010 The tee that came with the kit does not fit the fpr doing the test without it is not ideal but it seemed to be normal I need to find a smaller hose Link to comment Share on other sites More sharing options...
